  4. ABB Robot Forum
S4C+ Critical errors
  • Nortech
  • October 14, 2019 at 8:57 PM
  • Nortech
    88
    Hi all,
    I’m having issues with two S4C+ 6650 that we have. The errors are:
    Error 38665 Motor/Cables for joint 4 have a short circuit
    Error 38664 An intermittent short circuit was detected in motor/cable for joint 4
    other robot:
    Error 38600 incoming voltage to DC-link too low to DC link A2 in cabinet 1 single phase missing.
    if any one can provide any assistance with these error, that would be great.
    Every time these errors occur, the tech must stop production, enter the cell and manually clear the error. While we are trying to fix the issues, can anyone tell me how to set up a remote acknowledge error for critical errors such as these so that the operator does not need to enter the cell?
    Many thanks
  • Nortech
    88
    • October 14, 2019 at 8:58 PM
  • Nortech
    88
  • Lemster68
    295
    2,454
    Blog Articles
    7
    • October 15, 2019 at 12:00 PM
    Please tell us first what does the operator have to do to clear the errors? Why enter the cell? Is the teach pendant in the cell?
  • Nortech
    88
    • October 15, 2019 at 12:43 PM
    The operator clicks acknowledge on the teach pendant to clear the error. Sometimes they have to acknowledge the error several times before the robot will start again.
    The controllers have been installed in the cell since day one and it’s not easy to move.
    Is there a way to clear the critical errors remotely in the same way as the ackErrors system input?
    More importantly, has anyone got any information on the errors?
    many thanks.
  • Lemster68
    295
    2,454
    Blog Articles
    7
    • October 15, 2019 at 1:23 PM
    So you already have the AckErrorDialog system Input? So then, a fault reset should follow, PLC waits for faulted output to go low, send motor on and start next.
  • Nortech
    88
    • October 16, 2019 at 7:26 AM
    I will have to check it again but I was of the opinion that critical errors such as the ones in the photos could not be cleared in the way you described. Is this true?
  • Nortech
    88
    • October 16, 2019 at 9:42 AM
    Just found what you’re talking about. I’ll give that a go. Thanks
  • Nortech
    88
    • October 16, 2019 at 9:22 PM
    Does nobody out there have info on the errors that I am experiencing?
    Surely these aren’t the first robots to have them.
    Any help is much appreciated.
  • Skooter
    167
    2,005
    • October 17, 2019 at 5:26 AM
    Had the 38600 and on rare occasion it would also give the 38644. Traced it down to a breakdown under voltage of the insulation of a motor wire in the controller-to-robot motor power cable. Found it with a megger (insulation tester) set at 500V by disconnecting the motor power cable from both ends and checked each wire to the cable shield wire / connector shell. After finding which wire, took the connector shell off and found that wire was too short and pulled tight on a sharp edge that was cutting in to the wire enough to breakdown under high voltage of motor power but checked fine with the very low voltage of an ohm meter.
  • Nortech
    88
    • October 17, 2019 at 8:28 AM
    • #11
    Thanks for that detailed reply skooter. Makes perfect sense. I’ll check that next time in on site.
    thanks again.
  • Sahil Chaudhari
    • March 10, 2022 at 5:32 PM
    • #12
    Hello.... was this problem solved?
    I am having the following error:
    Error 38665 Motors/Cables for Joint irb_1 have a short circuit .Maybe caused by a faulty motor/cable or a contamination in contactors for cables or motor windings.
    Please help. Thanks!
  • Nortech
    88
    • March 10, 2022 at 8:44 PM
    • #13
    Yes, it was solved by replacing the faulty drive module.
  • Sahil Chaudhari
    • March 10, 2022 at 9:12 PM
    • #14
    Thanks!
    We were able to solve the earlier error
    "Error 38665 Motors/Cables for Joint irb_1 have a short circuit ".Maybe caused by a faulty motor/cable or a contamination in contactors for cables or motor windings"
    by fixing a cable that was broken. However,
    Its giving us a new error now: Error 37052: A voltage level measured on the main computer is outside of the tolerance.
    Measured: 3.3 V
    Expected: 3.0 V
    It had briefly given the same error earlier as well but then it had dissapeared.
    Has anyone encountered this error? and how to solve it?
    Thanks!
  • Skooter
    167
    2,005
    • March 11, 2022 at 6:06 AM
    • #15
    Assuming you have an S4C+ controller, there is a power supply inside the computer unit that supplies the 3.3V to the backplane for use by the CPU, I/O & Axis boards, Monitor the 3.3V to verify it is 3.3VDC.
  • 851dave
    45
    • March 20, 2022 at 8:23 AM
    • #16
    the 3.3v error is a dead button cell battery on main computer motherboard
  • 851dave
    45
    • March 20, 2022 at 8:26 AM
    • #17
    just re read your post and i think it would be
    Measured 3.0v if it was the button battery so ignore my previous comment
Similar Threads
  • KRC1 / All of the programs have compilation errors
    • mrnl
    • November 18, 2018 at 9:29 AM
    • KUKA Robot Forum
  • MEMO-ERRORS RJ3 Controller HELP!
    • Brewton
    • November 1, 2018 at 10:08 PM
    • Fanuc Robot Forum
  • MELFA MVS without posture control
    • NHaman
    • September 28, 2018 at 4:05 AM
    • Mitsubishi Robot Forum
  • KUKA FSOE Error
    • K1406
    • September 12, 2018 at 7:40 AM
    • KUKA Robot Forum
  • UX120 Purchase
    • philgrady
    • August 3, 2018 at 8:42 PM
    • Kawasaki Robot Forum
  • faro laser
    • Martin84
    • March 22, 2017 at 11:17 PM
    • KUKA Robot Forum
  • kuka positioning accuracy
    • Casius
    • February 28, 2017 at 6:02 PM
    • KUKA Robot Forum
  • Unable to perform critical operations on a Kuka KRC4. Please help.
    • ashwinmudigonda
    • August 22, 2016 at 4:57 PM
    • KUKA Robot Forum
  • New to connecting with robots...
    • brordautomation
    • May 24, 2016 at 10:44 AM
