Hello guys
Recently I was working with a KRC1 and I wanted to Input a new tool's dimensions but before that I only changed all dimensions of last tools to zero. It was late that day so I only turned the robot off then tomorrow I came back and turned the controller on to continue my works and to add new tool's dimensions, What I saw was a mess
I did nothing and see this right after the controller booted.
This is what happened:
- All of the programs had compilation errors so all of the TECH stuff like arc or gripper,etc had initialization failure
- Even bas.src had compilation errors
- Monitoring position show "Invalid Value" in those text boxes
- I opened tool numeric input, there was only 1 tool and the (+ -) button to change the toll number was not working and kept sending this error:"Object not found" then I inserted 2 in the Tool no. box via keyboard but this error appeared: "Value range overflow Tool no. (1-1)"
What I did:
First I checked if robot can move or not, fortunately it can move. then I tried to open some random programs, as I expected all of actions sent the error "[Prog name] not correct".
After that I headed back to the tool numeric input window and changed all of dimension (X,Y,Z,A,B,C) from 0 to 1. It strangely changed and didn't expect so even with that, nothing happened.
I tried loading everything from hard disk's archive (from menu FILE -> Load all from hard drive), nothing changed.
I tried shutting down the robot with or without cold start but nothing happened.
I was looking for the file which is related to tool's data but couldn't find it yet. (I'll keep searching)
Any Idea what to do next?
** Images are attached **
Thanks, Reza
