Kuka KR C2 with KCP2
  • GyooDev
  • March 20, 2024 at 10:38 AM
  • GyooDev
    5
    Hi, I'm working on a project and I need a little help. In the KCP2 there is a button for override speed. Which is the parameter that stores this speed of the robot when we use +/- from the joystick. I need it to integrate it on a program. To get it's current speed from the pad to store it on a different variable and then use it on a different place.
  • 95devils March 20, 2024 at 10:42 AM
    Approved the thread.
    Fubini
    278
    1,889
    • March 20, 2024 at 10:56 AM
    Could be $OV_JOG but I am not totally sure about this.
    Fubini
  • Roland Keller
    5
    65
    • March 20, 2024 at 11:01 AM
    $OV_PRO
    SkyeFire
    1,052
    9,429
    • March 20, 2024 at 3:13 PM
    The jog speed is $OV_JOG. The program execution override is $OV_PRO.
  • GyooDev
    5
    • March 20, 2024 at 3:24 PM
    How can we make this two inline commands
    LIN Xara_nokta and PTP Xara_nokta5
    To be continues movements without stopping on these points
    panic mode
    1,280
    13,085
    • March 20, 2024 at 4:25 PM
    those lines are already setup to be approximated. also the $ADVANCE is greater than 0.
    what remains to be seen is what the value of $APO is and if any of the other instructions stop advance run pointer. for example if Product_Height is a signal rather than variable it will be treated as I/O and therefore cause advance run stop.
  • GyooDev
    5
    • March 20, 2024 at 5:00 PM
    Product height is a variable for the product that we use to calculate the Z on pick and place
    SkyeFire
    1,052
    9,429
    • March 20, 2024 at 9:15 PM
    Quote from GyooDev
    That photo is so small as to be unreadable. Post actual code.
  • GyooDev
    5
    • April 2, 2024 at 6:28 AM
    Sorry about the late answer
    Here is the new img https://pasteboard.co/wwMwfcq2smFv.jpg
Similar Threads
  • KCP2 ed05 membrane replacement
    • Finn Poelseskind
    • February 25, 2022 at 11:15 AM
    • KUKA Robot Forum
  • Use of KUKA KR5-sixx-r650 without KCP panel
    • Bath_Cobots
    • June 9, 2022 at 2:18 PM
    • KUKA Robot Forum
  • Error running C:\KRC\BIN\StartKrc.exe
    • Gocea
    • December 19, 2021 at 11:31 PM
    • KUKA Robot Forum
  • KUKA KCP2 membrane tester
    • Gabigol
    • March 15, 2021 at 12:01 PM
    • KUKA Robot Forum
  • KRC2 WORKING WITHOUT KCP2
    • Bad_block
    • February 10, 2021 at 11:40 PM
    • KUKA Robot Forum
  • KCP2 Jogging problem
    • Ivascu Narcis
    • February 9, 2021 at 7:50 AM
    • KUKA Robot Forum
  • KUKA KCP2 Key Switch
    • Gabigol
    • December 17, 2020 at 3:38 PM
    • KUKA Robot Forum
  • $MOVE_ENABLE Input not allowed or $MOVE_ENABLE Eingang nicht Erlaubt
    • Brook
    • July 21, 2010 at 9:02 AM
    • KUKA Robot Forum
  • Teach Pendant Screen Black for a KRC2
    • tbarnes
    • February 15, 2020 at 2:00 AM
    • KUKA Robot Forum
