Offset Lines
  • madrjo3_RP
  • September 8, 2023 at 6:14 PM
  • madrjo3_RP
    27
    hi Team
    KUKA
    KRC4
    KSS8.6.6
    kr2700
    Help... I have a program with 50 points and I need to make an Offset at 40 movements in z- (10 mm) , Fanuc has a function called Tool offset and it allows you to do it in the number of lines that you choose, is there something similar in Kuka? or how could I do it? :neutral_face:
    Regards
    Saludos / Best Regards
    Madrijo3
  • Fubini
    278
    1,886
    • September 8, 2023 at 6:19 PM
    Expert programs or inline forms?
    In both cases you can in principle use the colon operator : aka geometric operator. How exactly and where to apply it to depends on the above question.
    Post
    RE: OFFSET in KR C4
    First of all one of the most often made mistakes. You can not use variables inside the aggregates (everthing between curly brackets). So
    (Code, 1 line)
    will not work because of the "Z Offset". You need to assign beforehand like this:
    (Code, 8 lines)
    This operation will not modify P1 but you have to think in which coordinate system you want to shift. Should the shift be happening in the base system the upper code is correct. If a shift in the tool system is required you need to change the order to…
    Fubini
    June 16, 2023 at 12:32 PM
    Fubini
    SkyeFire
    1,051
    9,426
    • September 8, 2023 at 7:15 PM
    Quote from madrjo3_RP
    Tool Z or Base Z? Once, as a permanent edit, or is this something you need to do dynamically as part of the program execution?
    Tool Z: Point = Point : {X 0,Y 0,Z -10,A 0,B 0,C 0}
    Base Z: Point = {X 0,Y 0,Z -10,A 0,B 0,C 0} : Point
    Fubini's link dives into the details.
  • madrjo3_RP
    27
    • September 29, 2023 at 6:17 PM
    i mean this is just a example
    ;Project: VW_9102NP
    ;Robot: RSP030RB02
    ;Fixture: RSP030TL01
    ;Process: Spot Welding SP
    ;Program: SW_RSP030TL01
    PTP HOME Vel=100 % DEFAULT ;%{PE}
    PTP P100 Vel=100 % DEFAULT ;%{PE}
    PTP P110 Vel=100 % DEFAULT ;%{PE}
    PTP P130 Vel=100 % DEFAULT ;%{PE}
    LIN P140 Vel=100 % DEFAULT ;%{PE}
    LIN P150 Vel=100 % DEFAULT ;%{PE}
    LIN P160 Vel=100 % DEFAULT ;%{PE}
    ______________________________________
    what about if lite to apply an offset in Tool Z- just for the points 140,150,160,
    some like a
    "Ztool offset -5" apply just for this 3 points
    from of this points must to be Normal , without modifications
    thanks in advance
    Madrijo3
    panic mode
    1,280
    13,082
    • September 29, 2023 at 6:41 PM
    it looks like you are using inline forms but that is not real code
    for ILF based programs you can simply offset base
    you may move some or all points using either transform options on the smartPad or with OrangeEdit.
    check programming manual for system intergrator.
Similar Threads
  • Subprogram skips out of Main and shows Errors INTP-105 and MCTL-105
    • TP77
    • August 20, 2022 at 3:08 PM
    • Fanuc Robot Forum
  • Vision Offset Relative to Userframe
    • yttehs_ragas
    • August 29, 2023 at 3:25 AM
    • Fanuc Robot Forum
  • iRVision Part Pickup
    • edimmy
    • July 24, 2023 at 9:56 PM
    • Fanuc Robot Forum
  • Is there a way to apply an offset to multiple lines of TP?
    • campergat
    • June 22, 2023 at 4:05 PM
    • Fanuc Robot Forum
  • KUKA Dynamic Movementparameters
    • EXOR
    • September 30, 2022 at 6:54 PM
    • KUKA Robot Forum
  • Part placement is off by one position
    • AY_Robot
    • August 23, 2022 at 12:13 AM
    • Fanuc Robot Forum
  • How to get robot to safe space not matter what
    • cat91345
    • June 24, 2022 at 8:32 PM
    • Fanuc Robot Forum
  • IOSYS DI/DO changes
    • sasi1922
    • July 12, 2021 at 3:53 PM
    • KUKA Robot Forum
  • FANUC Offset with PR "in bulk"?
    • nutcase511
    • April 15, 2020 at 6:49 PM
    • Fanuc Robot Forum
  • Karel Log with Vision Registers Offsets
    • SXJ1988
    • October 18, 2018 at 6:47 AM
    • Fanuc Robot Forum
