Hi.
I have a problem with one robot when the robot brakes are released, it falls a little and sometimes gives a collision warning but only in T1. End efector weight is less than 2kg, the piece it grips weights almost nothing and Payload is set and correct.
It's a LrMate 200iD/7kg that is mounted on a wall, I've checked the variable where the mounting angle was stored and it was at 0, so I changed it to 90 through controlled start and mainteinance menu but this is still happening.
Robot with 0° on all axis is pointing up, connectors from the base are pointing to the floor, it's tightened and do not move and the structure do not vibrate.
After running the setup and changing the mount angle to 90, I've searched on the mechanical unit manual where it describes how the mounting angle is calculated but the way it's mounted it should be "-90" degrees instead of 90. In theory values accepted are 0-180, but if I put -90 it accepts and it shows on $Param_group[1].$mount_angle the -90 but problem still happens so I'm not sure if it's doing anything.
I really do not understand very well how this works since in theory if robot was mounted to the wall with the front part pointing to left or right instead of up/down from the floor, gravity forces would be different and with that configuration will not be taken into account... is there any more thing or config I should change other than this?
Thanks in advance.
