hello every one,
what is the difference between these two profibus CP5614 A2 cards? i have used left card in different KUKA controllers. but right card in unknwon for me.
thanks for any help
hello every one,
thanks for any help
Are they both for KRC2s? IIRC, the KUKA PB cards weren't regular Siemens cards -- although I think the hardware was the same, just the firmware was customized to operate in KRCs.
Just looking at the slot connector, it looks like one is PCI, and the other is... ISA? They appear to be for different motherboard generations.
Think it is pci and pcie. Isa has bigger contact pads.
Right card is not PCI or ISA card ,Although i can see CP5614 A2 lable on it but I can't find any compatible slot on KRC2 motherboard for it.
Short research on inet: left one is cp5614 a2 right one should be cp5614 a3.
The second key gap on the right one is the key for 3.3 volt supply.
This card should also fit into the same slot as the left one, the additional gap doesn't matter. But if it works in a Kuka, who knows?
Left side CP5613/14 ISA slot (up to KRC2, not KRC2ed05), right side CP5614 A2 PCI slot.
actually, both are PCI slots. ISA slots had fewer but larger contacts (lower density)
simple answer
use the one released by kuka
anything else is just a guess and may not work
