I'm setting up an ArcMate 120iB with an R-J3iB controller (ArcTool V6.40). I was going to set my program select mode to "other," but I can't find the program select menu (it should be under menu>setup). Is there some variable that hides the menu, or am I limited to RSR/PNS for starting the robot?
Prog Select menu missing
TitusLepic -
May 6, 2021 at 9:51 PM -
Only thing I can think of is the Quick/Full Menus toggle.
Nope, unfortunately. I do have a menu called "RSR/PNS" that will only let me toggle between PNS and RSR (no "style" or "other"). I'm able to send a start signal from my PLC but it will start whatever program is currently selected on the pendant; I want the start signal to only start one specific program. If there's another way other than "other" to do that, I'd like to know.
No possible in R-J3iB, change the controller to R-30iA, which is the first with the Prog select functionality
Choose PNS or RSR (knowing the difference, depending on your needs) and then use UI9-16 which chooses the program you need and finally start it. It won't start whatever program currently selected, but the one you've selected with PNS/RSR. The only thing is you need to name your program starting with PNSxxxx or RSRxxxx, where xxxx are digits corresponding to UIs and $SHELL_CFG.$JOB_BASE.
And the only one program to start -> you need to block from PLC side - just block using other outputs corresponding to robot UIs. Or don't configure it from robot side - configure only one UI that you need and other programs will be blocked
Quote
Are you sure about this? I set up a 6.4 robot in roboguide and it has the program select menu. Also the pendant help file talks about setting up "other." Lastly, I set $SHELL_CFG.$SHELL_EXT to TRUE and now "other" is showing up as an option on the PNS/RSR menu - but I haven't been able to get the program to start with the PLC.
I would just use PNS0001 as your main program if it doesn't have 'other' available.
To be honest I've never tested in 6.4 - the newest version in my R-J3iB robot is 6.3x, so there was no possibility fo other.
As I said before - just use one PNS0001 or RSR0001 (depends on your needs) and that's all.
Thanks. I mapped UI[9:PNS1] to the always on rack, tied UI[17:PNS Strobe] to the same physical input as UI[18:Production Start] and it's working now.
Well done
I'd prefer to have a control of UI[9] and on and off it when I wanted, but if your sollution suites your needs, that's fine
