Selection inadmissible - KUKA KRC4
  • Hello,
    I'm generating a code from RobotMaster for additive manufacturing, but when I try to select it in the SmartPad, it shows the error messagem 1360 "selection inadmissible". I've searched for it in the error list but don't know what may cause this problem (I am new to KUKA programming).
    I'm using a KRC4 controller and a KR 70 R2100 robot.
    The auto-generated code is:
    &ACCESS RVP
    &REL 1
    &COMMENT GENERATED BY ROBOTMASTER
    &PARAM TEMPLATE = C:\KRC\Roboter\Template\vorgabe
    &PARAM EDITMASK = *
    DEF Program_1()
    EXT BAS(BAS_COMMAND: IN, REAL: IN)
    INT I
    BAS (#INITMOV, 0)
    ;******SETTINGS FOR PTP MOTION***********************
    ;FOLD PTP $VEL_AXIS AND $ACC_AXIS
    FOR I=1 TO 6
    $VEL_AXIS[I] = 20
    $ACC_AXIS[I] = 50
    ENDFOR
    ;ENDFOLD (PTP $VEL_AXIS AND $ACC_AXIS)
    ;******SETTINGS FOR LIN AND ARC MOTION***************
    ;FOLD LIN AND ARC MOTION VARIABLES
    $VEL.ORI1 = 200
    $VEL.ORI2 = 200
    $ACC.CP = 3
    $ACC.ORI1 = 100
    $ACC.ORI2 = 100
    ;ENDFOLD (LIN AND ARC MOTION VARIABLES)
    ;******SETTINGS FOR POSITIONING CRITERIA*************
    ;FOLD POSITIONING CRITERIA
    $APO.CDIS = 0.5
    $ORI_TYPE = #VAR
    ;ENDFOLD (POSITIONING CRITERIA)
    $BASE={X 660.0000,Y -1000.0000,Z 331.4000,A 0.0000,B 0.0000,C 0.0000}
    $TOOL={X 0.0000,Y -230.0000,Z 47.0000,A 0.0000,B -90.0000,C 90.0000}
    $ADVANCE = 5
    <thousands of motion commands>
    END
    It is something in the code or may be some configuration issue?
    Thanks!
  • I would advice You to open this program in WorkVisual and see if it point some syntax error.
    The normal behavior in this situation should be SmartPad pointing the errors itself, but If I remember correctly, I had this situation in the past.
    And also: what is the size of this program?
    These 3D printing programs tend to be huge, and KRC has a size limit regarding the contents or R1 folder. 10 MB or so.
  • according to header parameters, this file is visible (&ACCESS= ...V...) and therefore should be selectable.
    then V is missing, module is not "visible" and not selectable but it can be called from other programs
    DEF TEST()
    Program_1()
    END
    to toggle Visible parameter use smartPad menu Edit>Properties>Module Inf...
  • I change the Visible parameters and solved the issue. Thanks!
    Thanks everyone for the hints.
