KUKA HMI ERROR
  • Proma
  • November 27, 2023 at 7:35 AM
  • Proma
    Hello,everyone,
    Here we have met a problem of KUKA robot's SmartPad.
    There is a robot (KR500 R2830 MT with KRC4 KSS 8.6) in our customer's factory and they have used it about 1.5 years.
    They said when they have a rest for about 1 hour at noon, there may have an error of "Connect to 172.17.0.1 failed" sometimes and and the list of smartpad will disappear. They have to restart the system to solve it.
    We have tired to replace a new smartpad, reload a new image to the KRC, exchange a new KPC, but all of these do not work.
    I found this error is related to the remote monitor, but our customer said they have ever never tried this one.
    Does you guyes have any experience of this problem?
    Thank you so much :face_blowing_a_kiss:
    Edited 2 times, last by Proma (November 27, 2023 at 11:54 AM).
  • HawkME November 27, 2023 at 11:56 AM
    Approved the thread.
  • Proma
    • November 30, 2023 at 3:14 AM
    The problem is so strange for us, we have tried a lot of methods to solve it. But all of these did not work.
    Could any gues help me to solve it :loudly_crying_face:
    Thanks in advance!
    panic mode
    1,294
    13,126
    • November 30, 2023 at 3:40 PM
    sounds like intermittent connection...
    and you already replaced smartPad and KPC.
    but did you check if KPC is operational during outage?
    you can check this by using external monitor or trying to read project using WorkVisual etc.
    if KPC is operational, you can rule out power problem (X961).
    next thing to try is replacing CCU and/or X19 interface.
  • M.Ozkan
    22
    5
    538
    • December 1, 2023 at 10:45 AM
    This problem has numerous causes. For example, if SmartHMI.exe stops working, it disconnects the KCP connection. If the PC restarts, the connection is disconnected. In case there is an issue on the Ethercat line, the connection is lost. If the PC cannot catch up with the vxwin cycle time, the connection is lost. The easiest method to identify is to take and examine the logs with KRCdiag.
  • Proma
    • December 2, 2023 at 7:18 AM
    Quote from panic mode
    Hello, Panic,
    Thanks for your reply.
    The next step we will do is using external monitor to check if the KPC is running normally when the error occurs. But the problem just occur sometimes, it will take some time.
    And CCU and X19 interface is the most likely reason in my opinion because we have replaced smartPAD and KPC. So we will replace it if we have other method.
    I'll reply to you if we have any progress.
  • Proma
    • December 2, 2023 at 7:23 AM
    Quote from M.Ozkan
    Hello, Ozkan,
    Thanks for your suggestion.
    I know how to do KRCdiag but have no experience to analyse the logs.
    So which file needs to be checked? Could you give me some guide?
    Thank you so much.
Similar Threads
  • Connection between hmi weintek and kuka
    • sovsovich
    • October 9, 2023 at 11:53 AM
    • KUKA Robot Forum
  • About kuka krc4 robot collision detection error acknowledge in auto mode..via HMI
    • jinesh rohit
    • March 8, 2023 at 6:23 AM
    • KUKA Robot Forum
  • Kuka tool no.3: Kuka Archiving Automation
    • asimo
    • May 1, 2009 at 7:53 PM
    • Manuals, Software and Tools for KUKA Robots
  • KRC2 Cross3 error
    • Atanas Goranov
    • December 9, 2021 at 4:05 PM
    • KUKA Robot Forum
  • EtherCAT timeout / No connection to KRC
    • rydeck
    • August 11, 2020 at 8:29 PM
    • KUKA Robot Forum
  • emergency stop inoperative
    • wt93049
    • September 16, 2021 at 10:09 AM
    • KUKA Robot Forum
  • KUKA external axes.
    • capital9
    • November 29, 2021 at 3:11 PM
    • KUKA Robot Forum
  • KUKA collision detect/torque monitoring
    • ParkerAT
    • January 8, 2020 at 7:16 PM
    • KUKA Robot Forum
  • Invalid RDP Credentials / No HMI / Flashing underscore
    • rydeck
    • January 26, 2020 at 12:15 AM
    • KUKA Robot Forum
  • KUKA KRC2 OfficeLite 5.2.OL FLEXlm License Finder
    • EngineerTex
    • December 17, 2019 at 5:23 PM
    • KUKA Robot Forum
