I have Cross3Krc#0: Cmd timeout err.
Any Idea what is the problem.
My kuka is
VKRC2 ed05,
KRC 5.6.8
windows xp
My kuka is
VKRC2 ed05,
KRC 5.6.8
windows xp
have you checked the log files?
During boot? During production? On specific events, or at random intervals?
it was at 10%
I would expect vxworks did not not start (10%)
Log files are needed!
If VxWorks gets stuck during start, the usual suspects are, from most to least likely:
1. File corruption (re-install KSS)
2. Hard drive issue (bad sector, try a new hard drive)
3. Motherboard: Usually RAM needing replacement, but sometimes it's the motherboard itself.
or just simply send log files (there should be a lot of them)
you also could try a communication with telnet - this could help you as well
I try to change RAM but it not worked.
This is the log file.
12:37:14 .Getting version from registry
12:37:14 .Version: "V5.6.8"
12:37:14 .KRCVersion: "KR C"
12:37:14 .Reading "timeOut" = "120"
12:37:14 .Reading "trayIcon" = "true"
12:37:14 !Cannot find path: "//configuration/kukaroboter.startkrc/kukaVga"
12:37:14 .Starting KRC
12:37:14 .Running "C:\WINDOWS\KUKA\USB\WBF_BIOSReboot.exe"
12:37:14 .CreateProcess succeeded
.Commandline: "C:\WINDOWS\KUKA\USB\WBF_BIOSReboot.exe "
.Directory: "C:\WINDOWS\KUKA\USB"
12:37:14 .Running "C:\KRC\BIN\KukaDb.exe"
.Commandline: "C:\KRC\BIN\KukaDb.exe "
.Directory: "C:\KRC\BIN"
12:37:14 .Running "C:\KRC\HMI\KUKA_HMI.exe"
.Commandline: "C:\KRC\HMI\KUKA_HMI.exe "
.Directory: "C:\KRC\HMI"
12:37:14 .Waiting 120 secs ...
12:37:20 .WM_COPYDATA received: "Init"
12:37:20 .WM_COPYDATA received: "Start 10%"
12:38:58 .WM_COPYDATA received: "Init 20%"
12:39:14 .Timeout for splash screen
12:39:19 .Running "C:\KRC\BIN\LTCserver.exe"
12:39:19 .CreateProcess succeeded
.Commandline: "C:\KRC\BIN\LTCserver.exe "
12:39:19 .Starting service "KrcWmiProviderSvc"
12:39:21 .Service start pending...
12:39:22 !Service not started.
12:39:22 Current State: 2
12:39:22 Exit Code: 0
12:39:22 .Starting service "EscService"
12:39:22 .Service start pending...
12:39:23 .Service started successfully
12:39:23 .Starting service "KUKA Scheduler Service"
12:39:24 .Service start pending...
12:39:25 .Service started successfully
12:39:25 .Start sequence finished
12:42:11 .WM_COPYDATA received: "Init Softkeys 30%"
I don't have the KSS
This is HMI log file:
12/10/2021 12:37:19 Application Start
12/10/2021 12:42:11 Fail: KRCVariableProxy ShowVar $KCP_CONNECT Cross3Krc#0: CmdTimeout
12/10/2021 12:45:12 KUKARoboter.KRCModel.KRCException: Cross3Krc#0: CmdTimeout ---> System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component.
at PrimaryInterOp.Cross3Krc.ICKSyncVar2.ShowVarDP(String bstrDataPath, String bstrVar)
at KUKARoboter.KRCModel.CrossKrc.KrcVariableCommands.ShowVar(String path, String variable)
--- End of inner exception stack trace ---
at KUKARoboter.KRCModel.Robot.Variables.KRCVariableProxy.GetVarState(String name)
at KUKARoboter.KRCModel.Robot.Variables.KRCVariableProxy.StartSetInfo(String name, SetInfoAnswerEventHandler setInfoCallback, Object owner)
at KUKARoboter.KRCModel.Robot.Variables.VariableInfoImpl.add_Changed(EventHandler value)
at KUKARoboter.KRCModel.Robot.RobotImpl.KUKARoboter.KRCModel.Robot.IRobot.add_ModeOperationChanged(ModeOperationChangedEventHandler value)
at KUKARoboter.HmiToolbarCtrl.HmiToolbarKcpKeys.Initialize(KRCModelImpl krcModelImpl)
at KUKARoboter.HMI.KukaHmiForm.InitCommandBars()
at KUKARoboter.HMI.KukaHmiForm.OnSystemReady(Object sender, EventArgs e): MainWnd OnLoad() failed!
12/10/2021 12:47:05 OnHandleDestroyed: axSoftKeyBar - KUKARoboter.AxSoftKeyLib.AxSoftKeyBar
12/10/2021 12:47:05 OnHandleDestroyed: OvProStatKey - KUKARoboter.AxMoveStatKeyLib.AxOvProStatKey
12/10/2021 12:47:05 OnHandleDestroyed: MoveStatKey0 - KUKARoboter.AxMoveStatKeyLib.AxMoveStatKey
12/10/2021 12:47:05 OnHandleDestroyed: MoveStatKey1 - KUKARoboter.AxMoveStatKeyLib.AxMoveStatKey
12/10/2021 12:47:05 OnHandleDestroyed: MoveStatKey2 - KUKARoboter.AxMoveStatKeyLib.AxMoveStatKey
12/10/2021 12:47:05 OnHandleDestroyed: MoveStatKey3 - KUKARoboter.AxMoveStatKeyLib.AxMoveStatKey
12/10/2021 12:47:05 OnHandleDestroyed: MoveStatKey4 - KUKARoboter.AxMoveStatKeyLib.AxMoveStatKey
12/10/2021 12:47:05 OnHandleDestroyed: MoveStatKey5 - KUKARoboter.AxMoveStatKeyLib.AxMoveStatKey
12/10/2021 12:47:05 OnHandleDestroyed: ParamStatKey0 - KUKARoboter.AxParaStatKeyLib.AxParaStatKey
12/10/2021 12:47:05 OnHandleDestroyed: ParamStatKey1 - KUKARoboter.AxParaStatKeyLib.AxParaStatKey
12/10/2021 12:47:05 OnHandleDestroyed: ParamStatKey2 - KUKARoboter.AxParaStatKeyLib.AxParaStatKey
12/10/2021 12:47:05 OnHandleDestroyed: ParamStatKey3 - KUKARoboter.AxParaStatKeyLib.AxParaStatKey
12/10/2021 12:47:05 OnHandleDestroyed: ParamStatKey4 - KUKARoboter.AxParaStatKeyLib.AxParaStatKey
12/10/2021 12:47:05 OnHandleDestroyed: EAxisStatkey - KUKARoboter.AxMoveStatKeyLib.AxEAxisStatKey
12/10/2021 12:47:05 OnHandleDestroyed: IncStatKey - KUKARoboter.AxMoveStatKeyLib.AxIncStatKey
12/10/2021 12:47:05 OnHandleDestroyed: CoordStatKey - KUKARoboter.AxMoveStatKeyLib.AxCoordStatKey
12/10/2021 12:47:05 OnHandleDestroyed: OvJogStatKey - KUKARoboter.AxMoveStatKeyLib.AxOvJogStatKey
12/10/2021 12:47:05 OnHandleDestroyed: DomStatKey - KUKARoboter.AxMoveStatKeyLib.AxDomStatKey
12/10/2021 12:47:05 OnHandleDestroyed: - KUKARoboter.AxNewUserKeyBar.AxNewUserKeyBar
12/10/2021 12:47:05 OnHandleDestroyed: ModeStatKey - KUKARoboter.AxMoveStatKeyLib.AxModeStatKey
12/10/2021 12:47:05 OnHandleDestroyed: StepStatKey - KUKARoboter.AxMoveStatKeyLib.AxStepStatKey
12/10/2021 12:47:05 OnHandleDestroyed: axMenuBar - KUKARoboter.AxSoftKeyLib.AxMenuBar
12/10/2021 12:47:05 Error: Dispose Failed! Object reference not set to an instance of an object.
12/10/2021 12:47:05 at KUKARoboter.HmiToolbarCtrl.HmiToolbarBase.Dispose(Boolean disposing)
at KUKARoboter.HmiToolbarCtrl.HmiToolbarPin.Dispose(Boolean disposing)
at System.ComponentModel.Component.Dispose()
at System.Windows.Forms.Control.Dispose(Boolean disposing)
at System.Windows.Forms.Form.Dispose(Boolean disposing)
at KUKARoboter.HMI.KukaHmiForm.Dispose(Boolean disposing)
12/10/2021 12:47:05 HMI: Application End
I try Telnet 192.0.1.1 and it have some error ?
Is this VXWorks?
It says: no free memory left
what memory is this ?
VxWorks. At startup all programs and other stuff is downloaded from hard disk into the ramdisk container for VxWorks. Try to delete some programs from hard disk before starting (after back up of course).
Fubini
which program is loaded to RAM, that I can delete
Primarily all user programs (sec und dat) you do not need. What's not needed is up to you. Its not a single specific file. Basically everything underneath c:/krc/roboter/r1 is downloaded. Most people tend to place their user programs inside the program folder but thats not guaranteed. Anywhere under r1 would be valid.
I would do a backup of the program folder and then try to restart without anything in the folder just to see if it boots up then.
If this does not help I would try setting up Windows Embedded and KRC from scratch.
If this does not work either I would suspect hardware issues like defect hdd or ram.
Fubini
HDD, Mather board and RAM are OK.
I get image from another KRC2 and now everything is OK .
But I don't get where was the problem.
Thanks to all for your help.
File corruption on the hard drive, probably in the VxWorks executables. It happens sometimes.
...that brings me to another question, something I haven't tried on an ABB before: I've seen GOs and GIs that "overlap" with DO/DIs. Can I also do that with AOs and AIs?
That is, if I have DIs mapped to inputs 1-10 on a device, can I also have an AI mapped to the same inputs 1-10 on the same device?
