hi guys,
I was trying to make a communication between two controller, KRC4 to KRC4, i am using the topology like guven below:
KRC4 >> EL6695 >> Ethernet connection >> EK1110 >> KRC4
There are output and input terminals in between the Bus connection but i think it does not matter for the communication.
And actually in the EL6695, All the lights are green i.e Run prim, Run sec, and Power, which would suggest there is already a communcation but the problem is how to test the communication.
what is the easiest way to test the coimmunication?
For controller 1, i made workvisual file with 1 byte output for EL6695, and in another controller i made 1 byte input for EL6695, the ouputs were in group 1 to 8, similarly input for another controller was grouped from 1 to 8. but after that i dont know what should do to proceed further?
