Hello.
I have question about communication by KLI.
I'm wondering about pushing data from laptop on modbus via kli socket. Is this possible to use profinet and modbus on the same KLI port
Marek
Hello.
Marek
Hi, everyoneI would like to present a new software package we developed for KRC4/ KSS8. It called "ModbusTCP.KRC4". It is an add-on technology package with which KRC4 can as a modbus TCP server could communicate with other devices support the modbus tcp protocol directly. For example, a SIEMENS HMI Panel; a MES System.
But it is not a free software, if you are interesting, please
contact us:Apps.Support[at]reisrobotics.cn, PM meFunctions
ModbusTCP.KRC4 offers the following functions:
- Integrated KOP installer
- KRC4 as Modbus TCP server
- Map KRC Variables to the Modbus Registers
- Read and Write Global and Local Variables (.dat files)
- Support Modbus Function Code 03 : Read Holding Registers
- Support Modbus Function Code 16 : Write Multiple Registers
- Support importing configuration file, ready to use
- Both static and dynamic variable configuration mode (recipes)
Limitations
- ModbusTCP.KRC4 only supports numeric types: INT and REAL of KRL
Communication
- The communication between the device and the robot controller takes place via the KLI interface.
Our Apps
[list type=decimal]
- KicVarGateway - KRC4 Server App and Client SDK for TCP communication https://www.robot-forum.com/robotforum/kuk…/kicvargateway/
- ModbusTCP.KRC4 - KRC4 as a Modbus TCP Server https://www.robot-forum.com/robotforum/kuk…modbustcp-krc4/
[/list]
Hi, I have send you the Message but I don't have any answer
You should probably also mention that you work for KUKA and the prices are consistent with regular techpacks.
That is, exorbitantly extortionate if bought after the configuration.
