trajectory offset
  • TheFatRat
  • April 12, 2021 at 9:33 AM
  • TheFatRat
    18
    Good afternoon, I am using a laser sensor and kuka RSI 3.1 with kss 8.2.20.
    I want to implement the adjustment of the robot in coordinates depending on the detail, I wrote a server application that reads the current coordinates of the robot relative to the base coordinate system of the detail. The app works, but I need to implement tool offsets. An example of a trajectory in the figure, I read a blue trajectory with a laser and then my tool with a tcp point repeats the blue trajectory, but I need tcp to repeat the green trajectory. How can you make these displacements on the entire path, I tried to change the tcp calibration of the tool and specify the required displacement, the whole contour is displaced. To change the path, I need to use the face normal. Is it possible to use the TTS coordinate system for this?
    Images
      • 34.16 kB
      • 490 × 798
      • 37
  • Mentat
    61
    5
    243
    • April 12, 2021 at 2:11 PM
    If I understood you correctly, then you want to do translation and scaling. Changing base/tool coordinates by offset can only perform translation (hence the "whole contour is displaced").
    I suppose you could find the center of the part and translate all the points towards it.
  • TheFatRat
    18
    • April 13, 2021 at 6:27 AM
    Has anyone had any experience with having the instrumental coordinate system in the TTS coordinate system using Trafo_robframe in RSIVisual?
    panic mode
    1,280
    13,085
    • April 13, 2021 at 5:43 PM
    it is unclear how the "TCP follows blue line". do you use tool orientation? how? what is the tool orientation? normal to what? in 3D space there are three mutually normal vectors.
    if you programmed blue path correctly (using correct tool orientation) then changing TCP will allow you to follow green line. there is also tool correction used in hemming. whichever way you look at it you need to keep track of correct tool orientation.
    it is not enough to have the laser perpendicular to plane where the contour is, it should be also rotated along the path too... if not, you need to create more complex transform and recalculate points.
  • TheFatRat
    18
    • May 19, 2021 at 6:17 AM
    Thanks for the answers, I managed to make the setup and get the correct work. I selected the TTS coordinate system in poscorr and the robot began to track the trajectory correctly.
Similar Threads
  • Arcmate 120ib Seam Tracking and Touch Sensing
    • shalestamp
    • July 23, 2013 at 4:33 PM
    • Fanuc Robot Forum
  • Make a Multilayer using TECH
    • fuzzy_l
    • March 20, 2021 at 10:51 AM
    • KUKA Robot Forum
  • Orientation interpolation (KUKA doesn't use slerp)
    • Vlad222
    • June 22, 2020 at 4:19 PM
    • KUKA Robot Forum
  • IMOV doing strange stuff
    • vmec
    • June 5, 2020 at 9:04 PM
    • Yaskawa Motoman Robot Forum
  • Programming trajectory in Sim Pro
    • Patrik Paukov
    • May 18, 2020 at 5:29 PM
    • KUKA simulation software
  • visual servoing with kuka iiwa
    • hsadeghian
    • January 7, 2019 at 9:43 AM
    • KUKA LBR IIWA
  • Using offsets in UR
    • Nortech
    • November 14, 2018 at 10:35 AM
    • Universal Robots
  • laser sensor
  • trajectory offset
  • kss 8.2.20
  • TTS
