KUKA KRC4 EDS
  • legityme
  • December 2, 2020 at 9:08 PM
  • legityme
    85
    Hello guys!
    Quick question, what is the function of the EDS on the KRC4 standard? We have one EDS, on the RDC, and there's a missing one on the CCU. Why does the robot does not accuses a failure because of this missing EDS? What happens if we don't have them both? Or don't have them at all?
    Thank you!
  • panic mode
    1,296
    13,136
    • December 2, 2020 at 9:56 PM
    One on RDC is always used. It stores robot info. this allows RDC to be replaced without having to bring back all the info like in the past. old RDC had flash memory soldered onto RDC itself, but on KRC4 this is separate unit that plugs into RDC which is more flexible. also KRC4 stores more info on that EDS including network and safety config. if this EDS is missing or faulty,
    EDS in the KRC4 was not fully used by old KSS (before KSS8.3), so even if missing or faulty you would not see KRC4 complaining.
    But KSS8.3 and newer use it to store info for KPP, KSP, RDC etc. This allows you to take one of drive packs out, drop in replacement and power up. KSS will figure out which of them was exchanged and will automatically adapt FSoE address etc.
    But if you replace more than one... (for example you swap placed of two KSP in same controller) KSS will not try to figure it out and fix on its own. You would have to use WorkVisual and manually assign correct FSoE address to each of nodes and confirm that by serial number of the unit.
  • legityme
    85
    • December 3, 2020 at 2:49 PM
    Hello Panic Mode,
    Thank you for your reply! So what happens if we don't use a EDS on the CCU? We're using KSS 8.2.25 and 8.3.39.
Similar Threads
  • KRC4 OPC-UA Server, linking OPC-UA nodes to custom defined variables
    • Carty
    • November 12, 2020 at 3:47 PM
    • KUKA Robot Forum
  • Selection of default Tool and Base after powerOn/Restart
    • Sar92
    • November 10, 2020 at 4:40 PM
    • KUKA Robot Forum
  • KUKA KRC4 Program selection by PLC
    • mcalvo027
    • November 16, 2020 at 1:25 PM
    • KUKA Robot Forum
  • KUKA Programming tools
    • loopindex
    • November 3, 2020 at 9:47 PM
    • KUKA Robot Forum
  • Transfare program from KRC2 to KRC4
    • aljazkrizan
    • November 30, 2020 at 12:29 PM
    • KUKA Robot Forum
  • KUKA KRC4 WITH ONE AXIS
    • legityme
    • November 25, 2020 at 8:43 PM
    • KUKA Robot Forum
  • Kuka KRC4 id
    • manhunt
    • November 6, 2020 at 12:22 PM
    • KUKA Robot Forum
  • KUKA EXTERNAL AXIS (non Kuka axis)
    • emmanuel verite
    • November 3, 2020 at 5:18 PM
    • KUKA Robot Forum
  • KRC4 Hard drive
    • D_DeVanney
    • November 3, 2020 at 6:01 PM
    • KUKA Robot Forum
  • EDS
