Syntax for command files (.CM)
  • Alright, I got one more.
    set Zero % Override to "TRUE" via system variables
    I tried $MCR.$OVRZERO_ENB ... I don't believe that is the right SV, and cannot fond the correct.. thanks in advance!!
  • Hello,
    I keep having trouble using PCVLOAD to load files when the software number of the robots changes. We use the following command to load the current Ethernet configuration to the robot:
    PCVLOAD UD1:\ethercat.sv
    If the software version changes, we get the error: "Sys mismatch" and the script aborts.
    If we try to load the file manually, it asks "Convert? Yes, No." and with a click on Yes, the file converts and loads without problems.
    Is there any way to put Convert yes in the script to avoid aborting?
    • Helpful
    At the moment I'm a bit lost, can someone explain how a .CM file is started/loaded? I can't remember how it's done. When I try to load one, the error is: xxx.CM is not loadable.
    EDIT: Found the solution: Just press "Enter" on the file screen :), Always tried the softkey 'Load'. :(
  • An other exemple of .cm syntax
    PRINT "azertyuiop"
    DELAY 1000
    DEFPROG *SYSTEM*
    SETVAR $FNO "E-101165"
    SETVAR $HOSTENT[17].$H_ADDR "10.143.69.30"
    SETVAR $TMI_SNMASK[1] "255.255.255.0"
    SETVAR $HOSTENT[20].$H_ADDR "10.143.69.254"
    SETVAR $HTTP_AUTH[1].$TYPE 4
    SETVAR $HTTP_AUTH[2].$TYPE 4
    SETVAR $HTTP_AUTH[3].$TYPE 4
    SETVAR $HTTP_AUTH[4].$TYPE 4
    SETVAR $HTTP_AUTH[5].$TYPE 4
    SETVAR $HTTP_AUTH[6].$TYPE 4
    SETVAR $HTTP_AUTH[7].$TYPE 4
    SETVAR $HTTP_AUTH[8].$TYPE 4
    SETVAR $HSCDMNGRP[1].$MACRO_REG 100
    SETVAR $SI_UNIT_ENB 1
    SETVAR $PLST_GRP1[1].$COMMENT "QSDFG"
    SETVAR $PLST_GRP1[1].$PAYLOAD 52
    SETVAR $PLST_GRP1[1].$PAYLOAD_X -33.07235
    SETVAR $PLST_GRP1[1].$PAYLOAD_Y 0.179398
    SETVAR $PLST_GRP1[1].$PAYLOAD_Z 22.64599
    SETVAR $PLST_GRP1[1].$PAYLOAD_IX 54528.49
    SETVAR $PLST_GRP1[1].$PAYLOAD_IY 64557.29
    SETVAR $PLST_GRP1[1].$PAYLOAD_IZ 37259.31
    SETVAR $PLST_GRP1[2].$COMMENT "CHARGE 22kg"
    SETVAR $PLST_GRP1[2].$PAYLOAD 74.5
    SETVAR $PLST_GRP1[2].$PAYLOAD_X -3
    SETVAR $PLST_GRP1[2].$PAYLOAD_Y -2
    SETVAR $PLST_GRP1[2].$PAYLOAD_Z 29
    SETVAR $PLST_GRP1[2].$PAYLOAD_IX 106100
    SETVAR $PLST_GRP1[2].$PAYLOAD_IY 147300
    SETVAR $PLST_GRP1[2].$PAYLOAD_IZ 58200
    SETVAR $PLST_GRP1[3].$COMMENT "CHARGE 15kg"
    SETVAR $PLST_GRP1[3].$PAYLOAD 67.5
    SETVAR $PLST_GRP1[3].$PAYLOAD_X -6
    SETVAR $PLST_GRP1[3].$PAYLOAD_Y -1
    SETVAR $PLST_GRP1[3].$PAYLOAD_Z 28
    SETVAR $PLST_GRP1[3].$PAYLOAD_IX 90200
    SETVAR $PLST_GRP1[3].$PAYLOAD_IY 127700
    SETVAR $PLST_GRP1[3].$PAYLOAD_IZ 53100
    SETVAR $PLST_GRP1[4].$COMMENT "INTERCALAIRE"
    SETVAR $PLST_GRP1[4].$PAYLOAD 52
    SETVAR $PLST_GRP1[4].$PAYLOAD_X -8
    SETVAR $PLST_GRP1[4].$PAYLOAD_Y 0
    SETVAR $PLST_GRP1[4].$PAYLOAD_Z 27
    SETVAR $PLST_GRP1[4].$PAYLOAD_IX 75000
    SETVAR $PLST_GRP1[4].$PAYLOAD_IY 104300
    SETVAR $PLST_GRP1[4].$PAYLOAD_IZ 41700
    SETVAR $PARAM_GROUP[1].$ARMLOAD[2] 3.00E+00
    SETVAR $PARAM_GROUP[1].$ARMLOAD[1] 4.00E+00
    SETVAR $OPWORK.$UOP_DISABLE 0
    SETVAR $SHELL_CFG.$CONT_ONLY 0
    SETVAR $SHELL_CFG.$USE_ABORT 1
    SETVAR $SHELL_CFG.$CSTOPI_ALL 1
    SETVAR $CR_AUTO_DO 37
    SETVAR $CR_T1_DO 38
    SETVAR $REMOTE_CFG.$REMOTE_TYPE 1
    SETVAR $IO_AUTO_UOP 1
    SETVAR $JINC.$JINC_ENB 1
    SETVAR $SCR_GRP[1].$HBK_ENBL 0
    SETVAR $IO_AUTO_CFG 0
    SETVAR $IO_AUTO_UOP 0
    SETVAR $SHELL_CFG.$PNS_ENABLE 0
    SETVAR $SHELL_CFG.$SEL_TYPE 9
    SETVAR $SHELL_WRK.$CUST_NAME "CELL"
    SETVAR $SHELL_CFG.$PROD_MODE 1
    SETVAR $SHELL_CHK[3].$ENABLE 1
    SETVAR $SHELL_CHK[3].$RESUME 1
    SETVAR $SHELL_CHK[3].$PROMPT 0
    SETVAR $SHELL_CHK[3].$WARN 0
    SETVAR $SHELL_CHK[3].$FORCE 1
    SETVAR $SHELL_CHK[7].$ENABLE 1
    SETVAR $SHELL_CHK[7].$RESUME 1
    SETVAR $SHELL_CHK[7].$PROMPT 0
    SETVAR $SHELL_CHK[7].$WARN 0
    SETVAR $SHELL_CHK[7].$FORCE 1
    SETVAR $REFPOS1[1].$COMMENT "home"
    SETVAR $REFPOS1[1].$ENABLED 1
    SETVAR $REFPOS1[1].$HOMEPOS 0
    SETVAR $REFPOS1[1].$DOUT_INDX 3
    SETVAR $REFPOS1[1].$PERCHPOS[1] -1.570796E+00
    SETVAR $REFPOS1[1].$PERCHTOL[1] 1.745329E-03
    SETVAR $REFPOS1[1].$PERCHPOS[2] 4.363323E-01
    SETVAR $REFPOS1[1].$PERCHTOL[2] 1.745329E-03
    SETVAR $REFPOS1[1].$PERCHPOS[3] 0.000000E+00
    SETVAR $REFPOS1[1].$PERCHTOL[3] 1.745329E-03
    SETVAR $REFPOS1[1].$PERCHPOS[4] 0.000000E+00
    SETVAR $REFPOS1[1].$PERCHTOL[4] 1.745329E-03
    SETVAR $REFPOS1[1].$PERCHPOS[5] -1.570796E+00
    SETVAR $REFPOS1[1].$PERCHTOL[5] 1.745329E-03
    SETVAR $REFPOS1[1].$PERCHPOS[6] 3.141593E+00
    SETVAR $REFPOS1[1].$PERCHTOL[6] 1.745329E-03
    SETVAR $REFPOS1[2].$COMMENT "home"
    SETVAR $REFPOS1[2].$ENABLED 1
    SETVAR $REFPOS1[2].$HOMEPOS 0
    SETVAR $REFPOS1[2].$DOUT_INDX 35
    SETVAR $REFPOS1[2].$PERCHPOS[1] -1.570796E+00
    SETVAR $REFPOS1[2].$PERCHTOL[1] 1.745329E-03
    SETVAR $REFPOS1[2].$PERCHPOS[2] 7.452556E-03
    SETVAR $REFPOS1[2].$PERCHTOL[2] 1.745329E-03
    SETVAR $REFPOS1[2].$PERCHPOS[3] 3.457497E-02
    SETVAR $REFPOS1[2].$PERCHTOL[3] 1.745329E-03
    SETVAR $REFPOS1[2].$PERCHPOS[4] 0.000000E+00
    SETVAR $REFPOS1[2].$PERCHTOL[4] 1.745329E-03
    SETVAR $REFPOS1[2].$PERCHPOS[5] -1.605371E+00
    SETVAR $REFPOS1[2].$PERCHTOL[5] 1.745329E-03
    SETVAR $REFPOS1[2].$PERCHPOS[6] 3.141593E+00
    SETVAR $REFPOS1[2].$PERCHTOL[6] 1.745329E-03
    SETVAR $REFPOS1[3].$COMMENT "bloblo"
    SETVAR $REFPOS1[3].$ENABLED 1
    SETVAR $REFPOS1[3].$HOMEPOS 0
    SETVAR $REFPOS1[3].$DOUT_INDX 4
    SETVAR $REFPOS1[3].$PERCHPOS[1] 1.454924E+00
    SETVAR $REFPOS1[3].$PERCHTOL[1] 1.745329E-03
    SETVAR $REFPOS1[3].$PERCHPOS[2] 3.458544E-01
    SETVAR $REFPOS1[3].$PERCHTOL[2] 1.745329E-03
    SETVAR $REFPOS1[3].$PERCHPOS[3] -6.232571E-02
    SETVAR $REFPOS1[3].$PERCHTOL[3] 1.745329E-03
    SETVAR $REFPOS1[3].$PERCHPOS[4] -3.438299E-03
    SETVAR $REFPOS1[3].$PERCHTOL[4] 1.745329E-03
    SETVAR $REFPOS1[3].$PERCHPOS[5] -1.506708E+00
    SETVAR $REFPOS1[3].$PERCHTOL[5] 1.745329E-03
    SETVAR $REFPOS1[3].$PERCHPOS[6] 1.167974E-01
    SETVAR $REFPOS1[3].$PERCHTOL[6] 1.745329E-03
    SETVAR $REFPOS1[4].$COMMENT "blabla"
    SETVAR $REFPOS1[4].$ENABLED 1
    SETVAR $REFPOS1[4].$HOMEPOS 0
    SETVAR $REFPOS1[4].$DOUT_INDX 36
    SETVAR $REFPOS1[4].$PERCHPOS[1] -1.570796E+00
    SETVAR $REFPOS1[4].$PERCHTOL[1] 1.745329E-02
    SETVAR $REFPOS1[4].$PERCHPOS[2] 1.144587E+00
    SETVAR $REFPOS1[4].$PERCHTOL[2] 1.745329E-02
    SETVAR $REFPOS1[4].$PERCHPOS[3] -5.919982E-01
    SETVAR $REFPOS1[4].$PERCHTOL[3] 1.745329E-02
    SETVAR $REFPOS1[4].$PERCHPOS[4] 0.000000E+00
    SETVAR $REFPOS1[4].$PERCHTOL[4] 1.745329E-02
    SETVAR $REFPOS1[4].$PERCHPOS[5] -9.787981E-01
    SETVAR $REFPOS1[4].$PERCHTOL[5] 1.745329E-02
    SETVAR $REFPOS1[4].$PERCHPOS[6] 3.141593E+00
    SETVAR $REFPOS1[4].$PERCHTOL[6] 1.745329E-02
    SETVAR $RSPACE1[1].$COMMENT "PALETTE"
    SETVAR $RSPACE1[1].$IN_EXTERIOR 1
    SETVAR $RSPACE1[1].$PRIORITY 1
    SETVAR $RSPACE1[1].$DOUT_INDX 2
    SETVAR $RSPACE1[1].$DIN_INDX 2
    SETVAR $RSPACE1[1].$LENGTH_VTEX 1
    SETVAR $RSPACE1[1].$FIRST_VTEX[1] 260.000
    SETVAR $RSPACE1[1].$FIRST_VTEX[2] -2600.000
    SETVAR $RSPACE1[1].$FIRST_VTEX[3] -2000.000
    SETVAR $RSPACE1[1].$SECND_VTEX[1] 2460.000
    SETVAR $RSPACE1[1].$SECND_VTEX[2] 3000.000
    SETVAR $RSPACE1[1].$SECND_VTEX[3] 2000.000
    SETVAR $RSPACE1[1].$CUR_TCP[1] 0
    SETVAR $RSPACE1[1].$CUR_TCP[2] -1253.099
    SETVAR $RSPACE1[1].$CUR_TCP[3] 349.928
    SETVAR $RSPACE1[1].$PRE_TCP[1] 0
    SETVAR $RSPACE1[1].$PRE_TCP[2] -1253.099
    SETVAR $RSPACE1[1].$PRE_TCP[3] 349.928
    SETVAR $RSPACE1[1].$ENABLED 1
    SETVAR $THRRDITABLE[1].$DO_NO 56
    SETVAR $THRRDITABLE[1].$THR_ENB 1
    SETVAR $THRRDITABLE[2].$DO_NO 53
    SETVAR $THRRDITABLE[2].$THR_ENB 1
    SETVAR $THRSDITABLE[1].$DI_NO 289
    SETVAR $THRSDITABLE[1].$DO_NO 83
    SETVAR $THRSDITABLE[1].$THR_ENB 1
    SETVAR $THRSDITABLE[2].$DI_NO 290
    SETVAR $THRSDITABLE[2].$DO_NO 84
    SETVAR $THRSDITABLE[2].$THR_ENB 1
    SETVAR $RSCH_LOG.$EXP_ENB 1
    SETVAR $RSCH_LOG.$DEFAULT_DEV 1
    SETVAR $SCR_GRP[1].$M_POS_ENB 1
    SETVAR $SCR.$MAXNUMTASK 10
    SETVAR $EXTLOG_SIZ 1000
    SETVAR $EXTLOG_REQ 1000
  • Hi Jhubb,
    I was playing with your command and i found how to setup another DIO,
    Input
    DIOASG 1 1 512 89 1 1 1
    DIOASG 1 672 48 89 14 1 1
    DIOASG 1 801 20 89 18 1 1
    Output
    DIOASG 2 1 512 89 1 2 1
    DIOASG 2 672 48 89 14 2 1
    DIOASG 2 801 20 89 18 2 1
    DIOASG 2 17 16 89 1 0 17
    where did you get this command "DIOASG"?, if you have a manual about this could you share with me?
    Regards.
  • I need help setting %MAXREGNUM in [*NUMREG*] using CM.
    I tried this:
    SETVAR [*NUMREG*]$MAXREGNUM 200    -> No error, but also no change
    SETVAR [NUMREG]$MAXREGNUM 200      -> No error, but also no change
    KCL SET VAR [*NUMREG*]$MAXREGNUM = 200 -> "Undefined parse syntax error"
    KCL SET VAR [NUMREG]$MAXREGNUM = 200   -> "Variable not defined"
  • Oh sorry i did'nt read carefully your first message. With a .Cm i think it will be complicated because you have to be in controlled start to do it (version 9.4, for older version it's different). You can test with system variables concerned. I hope i helped you a bit. good luck :)
    I tried this:
    Hi dha
    I use the example below :
    DEFPROG *POSREG*
    ! max PR
    SETVAR $MAXPREGNUM 299 ;
    EXIT
    After restart in "controlled start" to apply the change.
    then in "Start Cold"
  • Does this need controlled start? I tested in Roboguide and it works after just cold start.
