Does anyone know which system variable the Ref. Pos, Status of an IRVision setup is stored?
thanks
thanks
They are not stored in system variables, they are stored in the xml file that represents the vision process.
Nation Do you work for Fanuc like how do you just know this info
Lol, nope. I had a job where I needed to pull that information out, so I started digging around in the vision process files and I found the reference position data there.
Can you modify the numbers from the .XML file and then dump them back into the robot?
Good question, I've never tried it. I believe you could.
What are you trying to achieve?
