Error when deploying or merging Workvisual to KRC
  • Hi everyone,
    I'm hoping someone can point me in the right direction to solve this error please?
    KRC4 KSS 8.5.8 HF1 Workvisual 5.0
    I have made a change to the IO mapping and attempt to Generate Code (or deploy and merge) the updated project to the KRC. It fails the verification with the following:
    Parse-Error in File KRC:\Steu\Mada\$option.dat on Controller KR 16 R2010-2
    The plug in Robo TeamComponent caused an error during code generation!
    We only have 1 robot and I can't find any reference to Robo Team being installed on the KRC or Workvisual. I've also reverted to the iniitial project and tried deploying a Workvisual project with no changes yet it still errors in the same way so the one change I made to the IO mapping is probably not the issue here. We haven't made any changes to the option.dat file directly.
    Any pointers please? Thanks.
  • ok. You can lookout for variables $motion_coop and $prog_coop (names might be slightly different, because I do not have access to a controller). Both should be false if you do not have a roboteam installed.
  • Hi,
    Thanks for the info. Have checked the file and both the variables you mention are False?
    Here's the file off the KRC if this helps?:
    &ACCESS RV
    &PARAM VERSION = 1.0.0
    &REL 2
    DEFDAT $OPTION PUBLIC
    CHAR $V_OPTION[32]
    $V_OPTION[]="V1.0.0/KUKA8.3" ;VERSIONSKENNUNG
    BOOL $TECH_OPT=TRUE ;FUNKTIONSGENERATOR
    BOOL $TCP_IPO=TRUE ;GREIFERBEZOGENE INTERPOLATION
    BOOL $SEP_ASYNC_OV=FALSE ;Schalter fuer asynchrone Hand-Overrides
    BOOL $LOOP_CONT=FALSE
    CHAR $LOOP_MSG[128]
    BOOL $IDENT_OPT=TRUE
    INT $SINGUL_STRATEGY=0 ;0=NONE, 1=APPROX
    BOOL $MOT_STOP_OPT=FALSE ;AKTIVIERUNG "BLOCK EXTERNAL START"
    BOOL $CHCK_MOVENA=TRUE ;AB-UND EINSCHALTEN DER UEBERPRUEFUNG DER EINGANGSNUMMER VON $MOVE_ENABLE
    BOOL $COLLISAVOID=FALSE ;
    BOOL $MOTIONCOOP=FALSE ;
    BOOL $PROGCOOP=FALSE ;
    BOOL $T2_OV_REDUCE=TRUE ;TRUE = Overridereduzierung auf 10 % in Mode T2
    BOOL $VAR_TCP_IPO=FALSE
    BOOL $SPL_VEL_MODE_OPT=TRUE ; Defaulteinstellung fuer $SPL_VEL_MODE
    INT $SPL_PTP_PARA_OPT=2 ; Defaulteinstellung fuer PTP-Spline Parametrisierung
    BOOL $IMPROVEDMIXEDBLENDING=TRUE ; verbessertes gemischtes Ueberschleifen
    BOOL $IMPROVEDSPLINEGEOMETRY=TRUE ;verbesserte Spline Geometrie
    DECL STEP_ENUM $SPL_MIXEDBLENDING_OPT=#NONE ;Optimierungen des gemischten Ueberschleifens im Spline
    ENDDAT
  • Yep. Both false. So definitely no Roboteam. In the Workvisual folder on you hard disk you should find a file WorkVisual.log it should have more info on the exact problem of the Roboteam WorkVisual plugin. My guess would be your option.dat is missing a variable or it contains a variable that the roboteam plugin does not know and therefore chokes on this. I would backup WorkVisual.log than generate the project file and compare to the backup Workvisual.log. You should see a section added to the end of the file with info on the project generation process. If you can post this section as well I might find a hint on what is missing or what is unknown.
    On the other hand these type of compatibility conflicts usually are fixed by using the newest WorkVisual versions.
  • OK, just looking initially at log file, towards the end one line reads:
    Assembly tried to get a Model for KRC:\Steu\Mada\$option.dat on Controller KR 16 R2010-2 but the File could not be opened.
    I'll continue to try what you say too.
    Also, as I'm running KSS8.5.8 is it OK to run the latest WorkVisual software? From your comment it is.
  • Here's the last part of the log entry for a code generation due to length of message:
    13:04:59.99 [General: Information] ThreadId:14040 Assembly KukaRoboter.ToolBaseManagement changed content of variable MACHINE_FRAME_DAT in KRC:\R1\System\$config.dat on Controller KR 16 R2010-2 JB
    13:05:00.42 [General: Information] ThreadId:14040 Assembly KukaRoboter.ToolBaseManagement changed content of variable MACHINE_DEF in KRC:\R1\System\$config.dat on Controller KR 16 R2010-2 JB
    13:05:00.55 [General: Information] ThreadId:14040 Assembly KukaRoboter.ToolBaseManagement changed content of variable $LDC_CONFIG in KRC:\Steu\Mada\$custom.dat on Controller KR 16 R2010-2 JB
    13:05:00.63 [General: Information] ThreadId:14040 Assembly KukaRoboter.ToolBaseManagement changed content of variable JOINT_DEVICE in KRC:\R1\System\$config.dat on Controller KR 16 R2010-2 JB
    13:05:00.74 [General: Information] ThreadId:14040 Assembly KukaRoboter.RoboTeam changed content of variable $COOP_KRC in KRC:\Steu\Mada\$custom.dat on Controller KR 16 R2010-2 JB
    13:05:00.74 [General: Information] ThreadId:14040 Assembly KukaRoboter.RoboTeam changed content of variable $WS_CONFIG in KRC:\Steu\Mada\$custom.dat on Controller KR 16 R2010-2 JB
    13:05:00.75 [AllMessages: Error] ThreadId:13072 - Message: "Parse-Error in File KRC:\Steu\Mada\$option.dat on Controller KR 16 R2010-2 JB" - Tag: ""
    13:05:00.75 [General: Information] ThreadId:14040 Assembly tried to get a Model for KRC:\Steu\Mada\$option.dat on Controller KR 16 R2010-2 JB but the File could not be opened.
    13:05:01.71 [Errors: Error] ThreadId:14040
    Summary:
    --> MachineName: LAPTOP-PBUGVF4H
    --> TimeStamp: 03/10/2020 12:05:01
    --> FullName: KukaRoboter.CoreUtil, Version=1.1.3.0, Culture=neutral, PublicKeyToken=eae976646d224940
    --> AppDomainName: WorkVisual.exe
    --> WindowsIdentity: LAPTOP-PBUGVF4H\studi
    Exception Information Details:
    Exception Type: KukaRoboter.AtomsServices.Interfaces.CodeGeneration.PlugInException
    Message: Plugin 'RoboTeamComponent' caused an exception
    Data: System.Collections.ListDictionaryInternal
    TargetSite: System.Runtime.Remoting.Messaging.IMessage EndInvokeHelper(System.Runtime.Remoting.Messaging.Message, Boolean)
    HelpLink: NULL
    Source: mscorlib
    HResult: -2146233088
    StackTrace Information Details:
    Server stack trace:
    at KukaRoboter.CodeGeneration.ControllerCodeGeneratorsStep.RunControllerTransformers(IBaseQueries baseQueries, IDeviceController controller, IBuildRun run)
    at KukaRoboter.CodeGeneration.ControllerCodeGeneratorsStep.Run(IBuildRun buildRun)
    at KukaRoboter.CodeGeneration.CodeGenerationComponent.TransformProject(IList`1 controllers, Boolean suppressPackageBuilding)
    at KukaRoboter.CodeGeneration.CodeGenerationComponent.TransformProject(Boolean suppressPackageBuilding)
    at KukaRoboter.KrcOnline.Codegeneration.ProgressDialog.GenerateCodeAsync()
    at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
    at System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink)
    Exception rethrown at [0]:
    at System.Runtime.Remoting.Proxies.RealProxy.EndInvokeHelper(Message reqMsg, Boolean bProxyCase)
    at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(Object NotUsed, MessageData& msgData)
    at System.Action.EndInvoke(IAsyncResult result)
    at KukaRoboter.KrcOnline.Codegeneration.ProgressDialog.CodegenerationFinished(IAsyncResult ar)
    Exception Type: System.InvalidOperationException
    Message: Operation is not valid due to the current state of the object.
    TargetSite: KukaRoboter.AtomsServices.Interfaces.CodeGeneration.IFileModelWrapper GetModel[T](KukaRoboter.Atoms.Device.IDeviceController, System.String, Boolean, Boolean, System.String)
    HelpLink: NULL
    Source: KukaRoboter.AtomsServices
    HResult: -2146233079
    at KukaRoboter.AtomsServices.FileModelProvider.GetModel[T](IDeviceController deviceController, String filePath, Boolean existingFileExpected, Boolean readonlyModel, String callingAssembly)
    at KukaRoboter.AtomsServices.FileModelProvider.GetFileModel[T](IDeviceController deviceController, String filePath, Boolean existingFileExpected)
    at KukaRoboter.RoboTeam.CodeGeneration.Actions.ActionFactory.GetModel(String filePath)
    at KukaRoboter.RoboTeam.CodeGeneration.Actions.ActionFactory.<GetBuildSteps>d__34.MoveNext()
    at KukaRoboter.RoboTeam.CodeGeneration.RoboTeamTransformer.Process(IDeviceController item, IPlatformModel model)
    13:05:01.72 [AllMessages: Error] ThreadId:13072 - Message: "The plug in RoboTeamComponent caused an error during code generation!" - Tag: ""
  • What is the exact version of Your WorkVisual?
    5.0.9? 5.0.10?
    5.0.10 is the last one from 5.x series. If You are using this one, You can try, as Fubini pointed, a newer one, that is 6.0.12.
  • Crikey, upgrading to 5.0.10 allows me to generate code without an error!
    As an aside, if I make IO mapping changes, which is the best route to take to update the KRC? Deploy or Merge?
    I'll see how I get on when I've made my changes but thanks all for your guidance.
  • If the robot is already configured and running and you want to make some changes, You can simply deploy the whole project again.
    Merge is more used when you are commisioning a new robot, or inserting new elements that came from another robot / project / whatever.
    With Merge You have a granular control about what go to the controller, but the mistake chances also got bigger.
