G'day, all. Been away from AS language programming for a loooong time, and need a sanity check on the SPEED command. I need to reverse-engineer a series of path programs (sealer-type) from a backup, and I'm finding that these programs mix SPEED xx ALWAYS and SPEED xx mm/s ALWAYS semi-randomly throughout. All the critical motions are LMOVEs.
Now, IIRC, a SPEED xx ALWAYS command with no units simply sets the robot speed to xx% of... robot physical maximum? Any "upstream" settings of mm/s have no effect, correct? That is, any SPEED command overwrites any previous SPEED commands, without any interaction between their settings, correct?
The bottom line here is that I need to convert some of these programs to run on a non-Kawasaki robot (identical EAOT and dispenser), but the other robot needs mm/s values for its LMOVE-equivalent commands. I'm painfully aware that, at best, I'll only be able to get a rough approximation of the speed and have to hand-tune the final output on the other robot, but I'm open to suggestions from anyone whose Kawasaki experience is stronger than mine (certainly fresher! )
