I tried to program this Karel function to extract the data from the system of a FANUC LR mate 200ic 5L robot and save this data in a ".dt" file.
! TP Code
DO[1] = ON
RUN dataextract
J P[1] 100% CNT100
J P[2] 100% CNT100
J P[3] 100% CNT100
WAIT 3.00 (sec)
J P[1] 100% CNT100
J P[2] 100% CNT100
J P[3] 100% CNT100
DO[1] = OFF
PROGRAM dataextract
%COMMENT = 'LOG DATA RECORD'
%SYSTEM
%NOLOCKGROUP
%NOABORT=ERROR+COMMAND+TPENABLE
%NOPAUSE=ERROR+COMMAND+TPENABLE
%NOPAUSESHFT
VAR
logFile : FILE
filename : STRING[16]
duration : INTEGER
clock_var : INTEGER
period : INTEGER
timeInt : INTEGER
timeStr : STRING[18]
IntTQa1,IntTQa2,IntTQa3,IntTQa4,IntTQa5,IntTQa6 : REAL
IntTQa1Str,IntTQa2Str,IntTQa3Str,IntTQa4Str,IntTQa5Str,IntTQa6Str : STRING[4]
IntANGa1,IntANGa2,IntANGa3,IntANGa4,IntANGa5,IntANGa6 : REAL
IntANGa1Str, IntANGa2Str, IntANGa3Str,IntANGa4Str, IntANGa5Str, IntANGa6Str: STRING[4]
entry : INTEGER
status : INTEGER
test : INTEGER
clocky : INTEGER
-- routine to get internal torque measured on axis
ROUTINE GET_INT_TQ(active : BOOLEAN)
BEGIN
IF active=TRUE THEN
GET_VAR(entry, '*SYSTEM*', '$MOR_GRP[1].$CUR_TORQUE[1]', IntTQa1, status)
GET_VAR(entry, '*SYSTEM*', '$MOR_GRP[1].$CUR_TORQUE[2]', IntTQa2, status)
GET_VAR(entry, '*SYSTEM*', '$MOR_GRP[1].$CUR_TORQUE[3]', IntTQa3, status)
GET_VAR(entry, '*SYSTEM*', '$MOR_GRP[1].$CUR_TORQUE[4]', IntTQa4, status)
GET_VAR(entry, '*SYSTEM*', '$MOR_GRP[1].$CUR_TORQUE[5]', IntTQa5, status)
GET_VAR(entry, '*SYSTEM*', '$MOR_GRP[1].$CUR_TORQUE[6]', IntTQa6, status)
ENDIF
END GET_INT_TQ
-- routine to get angle of axis
ROUTINE GET_INT_ANG(active : BOOLEAN)
BEGIN
IF active=TRUE THEN
GET_VAR(entry, '*SYSTEM*', '$MOR_GRP_SV[1].$CUR_SV_ANG[1]', IntANGa1, status)
GET_VAR(entry, '*SYSTEM*', '$MOR_GRP_SV[1].$CUR_SV_ANG[2]', IntANGa2, status)
GET_VAR(entry, '*SYSTEM*', '$MOR_GRP_SV[1].$CUR_SV_ANG[3]', IntANGa3, status)
GET_VAR(entry, '*SYSTEM*', '$MOR_GRP_SV[1].$CUR_SV_ANG[4]', IntANGa4, status)
GET_VAR(entry, '*SYSTEM*', '$MOR_GRP_SV[1].$CUR_SV_ANG[5]', IntANGa5, status)
GET_VAR(entry, '*SYSTEM*', '$MOR_GRP_SV[1].$CUR_SV_ANG[6]', IntANGa6, status)
ENDIF
END GET_INT_ANG
-- main routine
BEGIN -- execute the program
clock_var = 0
-- begin the clock time count
CONNECT TIMER TO clock_var
period = 10 -- ms
duration = 100000000 -- ms
filename = 'UD1:\'+'Test'+'.txt'
entry = 0
status = 0
-- tests
test = 0
clocky = 0
-- get actual time and convert it into string
GET_TIME(timeInt)
CNV_TIME_STR(timeInt, timeStr)
-- open the log file
OPEN FILE logFile ('AP', filename)
-- write actual time and make a carriage return
WRITE logFile (timeStr, CR)
REPEAT
-- start recording
clocky = clock_var
test = clocky+period
GET_INT_TQ(TRUE) -- call internal torque routine
CNV_REAL_STR(IntTQa1, 2, 2, IntTQa1Str)
CNV_REAL_STR(IntTQa2, 2, 2, IntTQa2Str)
CNV_REAL_STR(IntTQa3, 2, 2, IntTQa3Str)
CNV_REAL_STR(IntTQa4, 2, 2, IntTQa4Str)
CNV_REAL_STR(IntTQa5, 2, 2, IntTQa5Str)
CNV_REAL_STR(IntTQa6, 2, 2, IntTQa6Str)
GET_INT_ANG(TRUE) -- call internal angle routine
CNV_REAL_STR(IntANGa1, 2, 2, IntANGa1Str)
CNV_REAL_STR(IntANGa2, 2, 2, IntANGa2Str)
CNV_REAL_STR(IntANGa3, 2, 2, IntANGa3Str)
CNV_REAL_STR(IntANGa4, 2, 2, IntANGa4Str)
CNV_REAL_STR(IntANGa5, 2, 2, IntANGa5Str)
CNV_REAL_STR(IntANGa6, 2, 2, IntANGa6Str)
WRITE logFile(clock_var)
WRITE logFile(';')
WRITE logFile(IntTQa1Str,CR)
WRITE logFile(IntTQa2Str,CR)
WRITE logFile(IntTQa3Str,CR)
WRITE logFile(IntTQa4Str,CR)
WRITE logFile(IntTQa5Str,CR)
WRITE logFile(IntTQa6Str,CR)
WRITE logFile(';')
WRITE logFile(IntANGa1Str,CR)
WRITE logFile(IntANGa2Str,CR)
WRITE logFile(IntANGa3Str,CR)
WRITE logFile(IntANGa4Str,CR)
WRITE logFile(IntANGa5Str,CR)
WRITE logFile(IntANGa6Str,CR)
DELAY(period)
UNTIL DOUT[1]=OFF
-- stop recording, close log file
CLOSE FILE logFile
END dataextract
But unfortunately, I got only an empty file and there is no result in the file, only that :
03-MAR-22 17:33
0;
And here is an example of the file I got
can you help me find out where the issue is coming from or can you give me another solution to save in real time the system data like internal joint torque, joint speed, etc...
Thanks in advance
