Where to find Configmon.ini in new WorkVisual ? KRC4. WOV.6.0.20
  • spp
  • March 27, 2022 at 10:17 AM
  • spp
    Hi
    Where to find Configmon.ini in new WorkVisual ? I know how to edit configmon.ini in SmartPad but it would be great to do it in WorkVisual .. I use KRC4 and WOV.6.0.20 now.
    I have a feeling that it was possible to find it somewhere with earlier WoV version.
  • robotecnik
    19
    568
    • March 27, 2022 at 11:51 AM
    Never done that, but in the last commissioning I participated into, I think setting variables in the watch list on WorkVisual while starting a debugging session made them appear in the list of monitoring variables.
    You can always check it if you are near the robot.
    Hope this helps.
    http://www.robotecnik.com | Robots, CNC and PLC programming.
  • DannyDJ
    67
    506
    • March 27, 2022 at 3:25 PM
    Quote from spp
    Hi
    I can only find it in the archive C/User/ConfigMon.ini...
  • Fubini
    283
    1,905
    • March 27, 2022 at 3:40 PM
    You can always manually add additional files to the project. As soon as you do this they are updated in the project and restored again at project restore.
    Fubini
  • massula
    205
    8
    1,439
    • March 27, 2022 at 9:32 PM
    Some KRC4 brings configmon.ini in its WoV projects out of the box, others not, I don't know why. But I suspect it is related with some software options.
    Anyway, as Fubini said, if the case is the former, it is possible to pull more files in WoV project editing the ProjectExternalFileList.xml file, that is located somewhere inside User folder.
  • panic mode
    1,297
    13,141
    • March 27, 2022 at 10:44 PM
    This only works if one puts some effort and configure what additional files are to be transferred when deploying or collecting WoV project.
    i do it on all of my projects so that regardless what form of backup comes back to me, i get all files i may want to do check things or troubleshot. One of the main reasons i do this is not ConfigMon.INI but the UserTech files (KFD/KFDX, icons, smartHMI*.config) and perhaps templates.
    Setup is simple once you know where to look. Key here is the C:\KRC\User\ProjectExternalFileList.XML
    Edit it an get project from KRC with more or less anything you want. Of course one important thing here is to not forget the ProjectExternalFileList.XML itself
    Then when you transfer project from KRC to WoV, you will see this:
    Of course you can make changes in WoV and deploy to KRC. I usually grab them from KRCDiag then in place as shown in above image add new folder called C, icon will turn into a drive icon. then you can add additional folders and files. Important thing is to use correct version of files for your KSS. And of course filenames and paths must match those on KRC.
  • Vergeithor
    37
    • April 23, 2024 at 10:41 AM
    Hi Panic mode,
    Thanks for the info, it really helped me to be able to save all the important files of the project like the configmon.ini. :thumbs_up::thumbs_up::thumbs_up:
    This is working for "showing" the files on the "Configuration and commissioning" window.
    But, do you know if there's a way to see files like the ones on the "Config/User/Common..." on the "Programming and diagnosis" window? Or as they usually requiere a reconfiguration it's useless to edit them there?
    The reason is that deploying the changes on the "Programming ans diagnosis" is much more faster.
    Thanks!
    "¿Funciona? NO LO TOQUES!"
  • massula
    205
    8
    1,439
    • April 23, 2024 at 3:15 PM
    As far I can tell, Programming and Diagnosis Workspace pull just the contents of KRC folder (R1 and STEU subfolders).
  • panic mode
    1,297
    13,141
    • April 23, 2024 at 3:30 PM
    that sounds right to me too and i rarely use Programming and Diagnosis Workspace since i have my own workflow and tools.
    the files you are after are under Robot\Config when viewed in workspace Configuration and commissioning
