Jog speed help
josephtoftjr -
October 29, 2021 at 5:44 PM -
josephtoftjr
October 29, 2021 at 5:49 PM Changed the title of the thread from “Jog/run speed help” to “Jog speed help”. -
Is the sfspeed UI signal on?
Can you tell me where I can find that?
You will find the UOP signals under MENU > I/O > UOP.
If you are in teach mode and the SFSPD signal drops to 0 (OFF) the override will be limited to the value of $SFJOGOVLIM. In your case it is 50.
Is this a brand new robot?
A couple of years ago Fanuc started shipping new robots with two motion groups installed. Try to create a program with only the first group, or do a full system software install, making sure to select the new personality, not the existing personality.
Before you do anything though, take an image.
