I am working with the Robot 2400L, S4C
I have an error with the joystick, do you know how to solve it? or do you know what the mistake might be?
It could be stuck, sensing that it is not at the 0 deflection point. It could be dirty in there. If you feel confidant enough to open it up you could clean it up, make sure that nothing is stuck. Otherwise change it with a spare if you have one.
The TP checks the joystick when it powers up. If the joystick reads anything, then it disables the joystick and gives the error.
Possible no-cost remedies:
1. Make sure the joystick is centered and nothing is touching the joystick when it powers up.
2. Check the joystick rubber boot and make sure nothing is stuck in it and it is very clean (cotton swabs work good), has no wrinkles and the handle easily centers when released.
3. Remove the TP back cover and make sure the connector from the joystick is fully seated. Be very careful not to pinch any wires when reassembling.
mostly you must replace the Joystick, but he is expensive
I have already cleaned and checked the joystick, I can´t find the solution, just repace it.
I will continue to report if i find another solution
