Robot points are off
  • Jerryl859
  • February 21, 2021 at 3:19 PM
  • Jerryl859
    74
    I recently set up a program and everything was fine. I am using tool frame 1 and user frame 0. All points were good. I came back this weekend and all points are now off, like they have been shifted from the original positions. I haven't made any changes to either frame and unless somebody else has done that without realizing it I'm not sure how this could have happened. Any ideas from anybody would be greatly appreciated. I really don't want to have to touch up all the points again.
  • HawkME
    570
    3,269
    • February 21, 2021 at 4:01 PM
    Most common issue is that something has physically moved. Check for loose bolts on robot base, end effector, and fixture. Check if the end effector is bent. Do you have everything anchored properly to the floor?
    Also, this is why you should teach a user frame and not use UF 0.
    People always claim the robot somehow changed position, but in my experience that has never proven to be true and the issue always ended up being mechanical.
  • Jerryl859
    74
    • February 21, 2021 at 4:28 PM
    everything looks fine as far as anything having moved. I checked the tool frame data and it looks like the x and y values have been erased. No idea how this happened. If I teach the tool frame again I should get closer to the original points. I didn't use a user frame because the table that holds the parts is cluttered with fixtures so I just used frame 0 so it would reference the robot world frame
  • HawkME
    570
    3,269
    • February 21, 2021 at 6:46 PM
    Glad you found the issue. Now just have to make sure someone isn't accidentally changing the program.
    As for your user frame, I would have taught a single frame for the table itself. If the table ever gets bumped out of position you will have to reteach everything.
  • Jerryl859
    74
    • February 21, 2021 at 7:00 PM
    Thanks for the help
  • Nation
    Typical Robot Error
    553
    1,935
    • February 21, 2021 at 11:42 PM
    If your table is fine, you can still teach a frame to it, and then convert your program to your frame. The frame convert utility under utilities will let you do this.
  • Midmeat
    • March 13, 2024 at 7:08 PM
    I seem to have this issue as well my robot being a new Fanuc Arc Mate 120iD/12L i set up 600+ line job and all the points are off about the same amount in various XYZ directions and but my TCP is point on. Very frustrated at the moment. Luckily Lincoln Electric is coming in to morrow so when i figure out what is happening ill be sure to drop you a line here to help you out.
  • ROBOT_G
    23
    241
    • March 14, 2024 at 4:40 PM
    There's some new utility that pops up when the controller is turned to setup utools and other stuff. This utility will erase the current utools values.
  • IRockWell
    105
    • March 20, 2024 at 8:46 PM
    Quote from Midmeat
    Did they figure something out?
  • Uraz
    • March 25, 2024 at 7:13 PM
    How was the problem solved?
Similar Threads
  • How to open XRC controller backups in MotoSim?
    • dunnat
    • February 18, 2021 at 1:25 PM
    • Yaskawa Motoman Robot Forum
  • Circular Parameter Inadmissible error, Brings robot to a halt.
    • Asylum2021
    • February 12, 2021 at 10:29 AM
    • KUKA Robot Forum
  • Load cell feedback
    • Ruddock984
    • November 14, 2019 at 7:56 PM
    • KUKA Robot Forum
  • Configuration errors
    • djshaun5
    • January 31, 2021 at 10:08 PM
    • Fanuc Robot Forum
  • Fanuc 30iA INTP-311 error after installing Ethernet/IP option
    • kbrobotics
    • January 25, 2021 at 3:19 PM
    • Fanuc Robot Forum
  • Function to set register at begging of the motion
    • PetrBroza
    • December 2, 2020 at 10:17 AM
    • Fanuc Robot Forum
  • FANUC robot repeatability issue for Handling Application
    • nikhilpotdar15
    • November 17, 2020 at 10:04 PM
    • Fanuc Robot Forum
  • Easy way to adjust all points in the programs? For example +5mm on Z for all points
    • Darkbound
    • November 20, 2019 at 7:10 AM
    • Fanuc Robot Forum
