R30-iB Maintenance
  • gio_926
  • July 7, 2020 at 6:34 PM
  • gio_926
    13
    Hey guys,
    I work with 4 R30iB/R2000 robots and I am auditing our spare parts list. I have spare motors, fuses, TP+cable, and motor+controller fans (we had one break). I was given a list of possible parts but I wanted to get some input as to what you think is necessary/important and most prone to failure. Obviously getting everything is the way to go but I'm not sure how much $$ approval I will get. For reference, our systems are 4 years old and run in a an environment with not much dust and no oil.
    PCB Main Board
    CPU card DRAM
    Servo Card
    FROM/SRAM
    Amplifier 6Ax control board
    Servo amp pcb
    back plane 2 slot
    E-stop unit
    power supply unit
    power pcb
    pcb Estop
    I was hoping anyone with experience can give their feedback as to which parts are more prone to going out (if any), or which you had go out more frequently?
  • CSaunders
    44
    • July 7, 2020 at 9:19 PM
    Your list is very good and covers most of the typical failures. You'll have to break down each component based upon cost, availability and risk. Some items may be repaired in house (e-stop unit), while other such as the CPU may not. If I had to add anything I would recommend a spare pulse encoder and (unfortunately) an axis 2 RV. You may also consider RMP cable sets, depending on your cable trays and such.
    I'm not sure how critical your 4 robots are, but it may be worth investing in a spare robot and/or cabinet to rob parts from (not sure on your system pricing, but spare parts are expensive as crap).
  • Erik Olsen
    60
    5
    193
    • July 7, 2020 at 9:25 PM
    Mechanical unit cable. I believe they are suggest replacement on a 4 year PM cycle, but Ive seen customers go 20 years without doing it once. Might be worth having one on hand and replace it on an as needed basis.
  • Skooter
    172
    2,057
    • July 8, 2020 at 3:02 PM
    I would put the E-Stop Unit and Servo Amp at the top of my list.
    This may be stating the obvious, but add Fanuc recommended grease & industrial grade batteries.
    Speak with Fanuc and see what delivery times and expediting costs are for the parts and compare this to the cost of downtime. Good info to have when negotiating with others for spare part money. CSaunders makes a good point regarding a used robot system as a spare.
    Don't forget to prevent issues. At 4 yrs, hopefully the robots have had the grease exchange done - Fanuc is known for not completely filling some of the grease cavities when the robots are assembled. Careful with the wrist of the R-2000iC, unlike the previous R-2000's, it has a separate inlet for axis J6.
    Optimizing robot paths and motion along with reducing unnecessary safety stops will save wear on the manipulator.
    Proper fusing and transient protection of I/O, safety chains and communication will help.
  • Apa
    • July 8, 2020 at 7:37 PM
    As was said, you have to know what risk the company can take. 48+ hours D/T is painfull for most automotive companies (means pretty expensive).
    If you can handle 48h D/T it can be covered by service contract with FANUC service center. The units from your list are handled in FANUC warehouse and could be delivered in 24h. Those are my experiences from middle EU region.
    Anyway, discuss it with your local FANUC service center.
  • Frank Yeh
    35
    • January 22, 2024 at 6:52 AM
    Could you good folks recommend a good vender for spare parts? I am looking at stocking an E-Stop Unit. Debating if I should get the whole unit, or just the magnetic contactors.
  • Skooter
    172
    2,057
    • January 23, 2024 at 1:06 AM
    Vendor depends on whether you are looking for used or new, untested or tested, as-is or refurbished.
    Hard to recommend whole unit or contactors when we don't know what controller you have.
    R-J3 likely to be contactors but with R-30iB/R-30iB+ and R-30iA & newer Mates, it more likely to be the PCB. Getting a whole unit can take some guess work out of troubleshooting. Depends on what your company's downtime tolerance & costs are.
  • Frank Yeh
    35
    • January 23, 2024 at 5:37 AM
    Thank you Skooter, we have the 15 year old R-30iA controller, which started to intermittently display the Srvo-348 dcs mcc off alarm code. So far, a power cycle and a few taps on the E-Stop unit would resolve the issue, but I am suspecting it is ether the relay switch on the PCB or the contactor itself that are reaching the end of their life cycle.
    We previously order through our integrator, but they seem to be charging a premium. For our company, they would prefer new stock. I will then refurbish the old unit as a backup. I have suggested getting a used controller as a backup, but the management is not keen on the idea.
    I am wondering other than ordering directly from Fanuc is there a reasonably priced vender that you would recommend. Thank you in advance.
  • Skooter
    172
    2,057
    • January 24, 2024 at 3:19 AM
    Outside of Fanuc for the R-30iA, finding new is going to be a surplus unit purchased from Fanuc at one time but not used and available for sale. An internet search of your part # will give options you can sort thru looking for new. Price is the big consideration.
    If you're open to refurbished then there are still lots of choices including Fanuc. Stick with a company having the robot systems to test them with after being repaired/refurbished and backs them up with a good warranty and make it right attitude.
    You may want to choose a company that also has good robot knowledge. When you're down, making a phone call can get quicker response than the good folks on the forum.
    Good customer service, setting your company on an account if making multiple buys, available field service, etc. are also considerations.
    Sorry for being indirect but I know quite a few people and it's hard to choose among friends or even your own employer.
  • Frank Yeh
    35
    • January 24, 2024 at 7:17 PM
    Thank you Skooter, I understand the possible conflict of interest.
    I completely agree with finding a company with good robotic knowledge and warranty. I have since ordered the part from our original integrator. They do charge a premium, but are also reliable.
    I have also purchased the PCB as well as the contactor to refurbish our existing E-Stop unit once it is swapped out. I appreciate your input!
  • pdl
    270
    1,548
    • January 24, 2024 at 8:44 PM
    • #11
    I'd be interested to know what they are actually charging. Are they an authorized Fanuc systems integrator?
    As an authorized integrator, you are not allowed to mark-up Fanuc's spare parts prices, you have to sell them at their list price. The only margin that an integrator makes on selling Fanuc spares is based upon the discount that the integrator receives off of the MSRP.
  • Frank Yeh
    35
    • January 24, 2024 at 10:56 PM
    • #12
    Hi pdl, the problem is that we don't have an account with Fanuc directly, so we can't see their list price. I have started the process of applying for an account, but it has been very slow on their end.
    It is good to know that Authorized integrators can't charge a premium. Thank you for your input.
  • Skooter
    172
    2,057
    • January 25, 2024 at 6:17 PM
    • #13
    With regards to contactors - change them both together. You may want to replace the large 4-pole relay on the PCB too.
    Just to add to pdl's post - an integrators discount increases with amount they purchase from Fanuc. If you're a good customer & purchase a lot with a large distributor, they may offer a discount off of list. The more they spend with Fanuc, the better for the integrator.
    You should get a Fanuc login. Pretty sure they'll quote you at list price if your login doesn't give pricing.
  • Frank Yeh
    35
    • February 1, 2024 at 7:00 PM
    • #14
    Skooter Thank you! We have just replaced the E-stop unit. I am also replacing both contactors and the E-stop PCB in the old unit, and using the old E-stop unit as a backup.
    Fanuc Canada is taking forever to set up an account for us (it has been 3 weeks). Without an account, they wouldn't assign us a login.
Similar Threads
  • Can't Clear Maintenance Reminder
    • Joan Mifsud
    • March 4, 2019 at 8:16 PM
    • Fanuc Robot Forum
  • Brake Number Conflict
    • Dnaines
    • December 16, 2019 at 10:44 PM
    • Fanuc Robot Forum
  • R30iB PM
    • iteody
    • February 26, 2019 at 11:49 PM
    • Fanuc Robot Forum
  • R30iB R2000iC/210F SSPC-103, SRVO-105 ERRORS
    • Charles Cornett Cornett
    • April 13, 2019 at 3:33 PM
    • Fanuc Robot Forum
  • Purchasing Cables
    • jonthegreek1
    • February 5, 2019 at 5:29 PM
    • Fanuc Robot Forum
  • 24vdc amperage available in controller
    • Skipp
    • September 25, 2018 at 4:21 PM
    • Fanuc Robot Forum
  • R30iB 120iC Adding Second Group
    • Beejaybarnes
    • December 21, 2017 at 11:26 PM
    • Fanuc Robot Forum
  • [solved-ish] Dual Arm R30iB B Style - 900ib600
    • CSaunders
    • June 21, 2017 at 6:01 PM
    • Fanuc Robot Forum
