Does anyone know how much current(24VDC) is available from the R30iB controller?
24vdc amperage available in controller
Skipp -
September 25, 2018 at 4:21 PM -
For I/O or ? First rule would always be if it draws more than 100mA of current then it should be driven from a relay that it rated for the current. For most of the I/O you provide the 24v but I would never use it to run anything that draws more than 100 mA.
What about at the EE connector ? Can I use that 24VDC to power a manifold and the 3 valves on it? Thanks in advance
Depends on what type of valve, but the controller maintenance manual for the the R30iB states that each RO port on the EE connector can source 0.2 amps of current.
I don't have a manual but I did see the RO current you mentioned in another post somewhere. I was looking for the current available from pins 17-20. Thanks
Looks like the 24V pins can supply up to 0.7 amps.
