Why cant i use User tool=2 or something before the program?
Pls explain the use??
To assign the active User tool you would use the normal command. But in some situations you may want to check what the currently assigned tool is. In that situation you could set a register equal to this system variable.
Can you please elaborate
can this variable be used for, knowing which user tool frame i am in.
Basically im trying to know what is my current user tool number
and make decision based on that?
QuoteBut in some situations you may want to check what the currently assigned tool is. In that situation you could set a register equal to this system variable.
R[1:Current Tool No.]=$MNUTOOLNUM[1] ;
