$VEL in Auto Vs Ext
  • MazdaTrio
  • August 21, 2013 at 6:58 PM
  • MazdaTrio
    I have a small problem with a program I have been working on. Currently I set the values of $Vel to the below
    $VEL.CP = 0.001 ;unit: [m/s]
    $VEL.ORI1 = 50 ;unit: [deg/s]
    $VEL.ORI2 = 50 ;unit: [deg/s]
    When I run my program in "Auto" the values are observed and the robot will reorient slowly. However when I place the robot in "Ext" the motion is very fast like the values are not being observed or being overwritten. Can anyone tell me if I am missing something.....
    Thanks in advance for any help given!
  • eusty
    721
    • August 21, 2013 at 7:08 PM
    After its moved in EXT what are the variables? Have they been overwritten?
    It's strange as AUTO and EXT should be the same.
    Sent using Tapatalk 4
  • MazdaTrio
    • August 21, 2013 at 8:54 PM
    When I monitor the variables they do change as expected. But the robot is still to fast in EXT mode.
    Thanks for the quick reply
  • Probo.dk
    Guest
    • August 22, 2013 at 1:19 PM
    $Advance=3 in EXT?
  • Fubini
    277
    1,884
    • August 22, 2013 at 2:33 PM
    what are the values of the main run variable $VEL_C ? $VEL ist the velocity in the advance run.
    Fubini
  • MazdaTrio
    • August 22, 2013 at 9:10 PM
    Quote from Lasse / Denmark
    $Advance=3 in EXT?
    Yes it is 3 when in EXT mode
    Quote from Fubini
    Fubini
    the values at startup are:
    CP = 2
    ORI1 = 200
    ORI2 = 200
    After I run my code they are:
    CP = 0.001
    ORI1 = 50
    ORI2 = 50
  • Fubini
    277
    1,884
    • August 23, 2013 at 6:44 AM
    Quote
    CP = 0.001
    ORI1 = 50
    ORI2 = 50
    I meant $VEL_C during execution in EXT when you robot is to fast, not after your program has finished. $VEL_C tells the programmed velocities of the currently executed motion (the one you see the robot doing at this moment). Hence this Test would reveal if in EXT somebody messed up your programmed data $VEL.
  • Probo.dk
    Guest
    • August 25, 2013 at 7:47 PM
    I'd just try with a $advance=1 in the beginning of the current program - and see if that would work...
    in that case - modify whatever config and set $advance in EXT to desired value...
    SkyeFire
    1,051
    9,422
    • August 26, 2013 at 3:20 PM
    I'm pretty certain that the advance run doesn't have any effect on when $VEL is evaluated -- otherwise the standard inline-form points generated by the KCP menus would never work properly.
  • ajey kumar
    • February 14, 2022 at 2:21 PM
    hi guys.. I m using Kuka kR10 and KRC4 controller and this is what I made for testing purposes, mentioned acceleration and velocity but when I tried to run in auto robot running with full speed. Can anyone help me for the same
  • panic mode
    1,278
    13,076
    • February 14, 2022 at 2:38 PM
    • #11
    you only programmed low speed for CP motions (LIN,CIRC) but not for PTP.
    my guess us that you jumped in horror and stopped program before reaching LIN instruction (line 11 for example). high speed motions you are observing are the PTP motion.
  • Fubini
    277
    1,884
    • #12
    Line 11 sets velocity to 0.5 m/s!
    Velocities for PTPs is not reduced. Use $VEL_AXIS[].
  • panic mode
    1,278
    13,076
    • February 14, 2022 at 2:40 PM
    • #13
    and Fubini is absolutely correct, line 11 is an inline form motion that changes speed for CP motions so low speed and acceleration values you had earlier are overwritten
  • ajey kumar
    • February 15, 2022 at 7:42 AM
    • #14
    Thank you guys, pls explain me why tool changing automatically in program. I want run certain positions with tool2 but it’s changing into tool1. I defined in program $tool=tool data[2]
  • hermann
    406
    2,607
    • February 15, 2022 at 8:01 AM
    • #15
    You are mixing up expert and inline movements, so you always have to focus on which tool was set in the last movement. In Inline movements always the tool is set as configurated in the inline Form.
  • ajey kumar
    • February 15, 2022 at 8:44 AM
    • #16
    I m just using only tool2, even in inline movements. This is how I made the program pls check and let me know where I need to correct
    Images
      • 675.5 kB
      • 1,200 × 1,600
      • 28
  • hermann
    406
    2,607
    • February 15, 2022 at 8:49 AM
    • #17
    Don't see any reason why robot should switch to tool 1.
    How do you recognize that he switches to Tool 1?
    Always send the ASCII files (src and dat), or even better a complete archive, don't send screenshots of a program, there can be hidden problems in the folds or .dat files.
  • Fubini
    277
    1,884
    • February 15, 2022 at 9:28 AM
    • #18
    No offense but: At best get formal basic training by e.g. KUKA. Your questions so far are very beginner like. This forum can not replace the basic training. And its intention is not to teach every beginner the basics.
    Fubini
  • ajey kumar
    • February 15, 2022 at 9:29 AM
    • #19
    I'm sending the SRC & DAT files of the program, pls check
    Files
    New folder.zip 2.48 kB – 9 Downloads
  • hermann
    406
    2,607
    • February 15, 2022 at 11:35 AM
    • #20
    Nothing to find in the src, that switches the tool to no 1.
    Once again:
    Quote from hermann
