Hello
One question, a robotic arm gives this error that is shown in the images, and then the SmartPAD appears on a black screen like Windows, what is the cause of this and how can it be solved? I have a KRC5 micro and a KR 4 R600
Hello
Kurulum aşamasında robota hangi IP adresini atadınız?
This is English forum. Please use English.
you have a software issue therefore type and size of robot arm is irrelevant. stating exact software version would be much better.
the first image shows error rather clearly file name and path. it is just a text file (XML to be more specific). you can try to open mentioned file to see what is inside. if corrupted, it will need to be replaced . you may just replace that file and perform cold start with reload files. or you can create backup and then restore known good hdd image.
Have you tried KRC Release?
