Controller version 8.23 ROBOGUIDE INSTALL
  • Jose Eduardo Tlalpan
  • September 14, 2023 at 11:06 PM
    Hi to everyone, I am trying to install the 8.23 version controller cause I need to run some backups on roboguide. The problem is I cant get the FRVC to add.
    Do anyone know how to get the version controller?
  • Nation September 14, 2023 at 11:34 PM
    Approved the thread.
  • retobor
    17
    202
    • September 15, 2023 at 7:32 AM
    I have versions of software that are built specifically for a certain customer, that isn't a FRVC supported version. However, I can edit the version and Build ID in the backdate.dt file to 'trick' RG into thinking it is a supported version. Not sure about V8.23, but you can give it a try. For example, I would edit V8.23/xx to V8.20/xx:
    Your backdate.dt file:
    20/11/23 01:57:44
    Version:  V8.23P/06/None
    Build ID: V8.23         4/10/2020
    1A05B-2500-H551
    1A05B-2500-H521
    1A05B-2500-J684
    1A05B-2500-J765
    1A05B-2500-R663
    1A05B-2500-J567
    1A05B-2500-R784
    1A05B-2500-R650
    1A05B-2500-R694
    1A05B-2500-R809
    1A05B-2500-R850
    1A05B-2500-J541
    1A05B-2500-J878
    1A05B-2500-R843
    1A05B-2500-J873
    1A05B-2500-R848
    1A05B-2500-J945
    1A05B-2500-J946
    1A05B-2500-H746
    Z
    Edit to:
    20/11/23 01:57:44
    Version:  V8.20P/06/None
    Build ID: V8.20         4/10/2020
    1A05B-2500-H551
    1A05B-2500-H521
    1A05B-2500-J684
    1A05B-2500-J765
    1A05B-2500-R663
    1A05B-2500-J567
    1A05B-2500-R784
    1A05B-2500-R650
    1A05B-2500-R694
    1A05B-2500-R809
    1A05B-2500-R850
    1A05B-2500-J541
    1A05B-2500-J878
    1A05B-2500-R843
    1A05B-2500-J873
    1A05B-2500-R848
    1A05B-2500-J945
    1A05B-2500-J946
    1A05B-2500-H746
    Z
  • PnsStarter
    90
    325
    • September 15, 2023 at 11:34 AM
    Like retobor wrote.
    This is the way to go!
    This will work or not, and sometimes you'll run into unexpected problems. Because there is a reason V8.23 exists.
    Otherwise ask fanuc or the "company" which uses V8.23 for the VRC version.
    Backdate/TP-Tools: A small collection of tools that simplify the commissioning and programming of Fanuc robots. (github.com)
  • pdl
    266
    1,504
    • September 15, 2023 at 5:09 PM
    Are you sure it is 8.23 and not 8.13?
    I can't seem find any references to a v8.23 anywhere in Fanuc's documentation. However, I do see a separate folder and an additional binary that is located in
    \\Program Files (x86)\FANUC\WinOLPC\Versions
    I haven't tried this, but you may want to look into \\Program Files (x86)\FANUC\Shared\Off Line\FRVRC\frvirtual.exe.config
    You may be able to add a listing for v8.23 that points to the correct resources for v8.20. This is just a WAG, but it might just work.
    • September 20, 2023 at 4:13 PM
    Quote from retobor
    20/11/23 01:57:44
    1A05B-2500-H551
    1A05B-2500-H521
    1A05B-2500-J684
    1A05B-2500-J765
    1A05B-2500-R663
    1A05B-2500-J567
    1A05B-2500-R784
    1A05B-2500-R650
    1A05B-2500-R694
    1A05B-2500-R809
    1A05B-2500-R850
    1A05B-2500-J541
    1A05B-2500-J878
    1A05B-2500-R843
    1A05B-2500-J873
    1A05B-2500-R848
    1A05B-2500-J945
    1A05B-2500-J946
    1A05B-2500-H746
    Z
    Edit to:
    20/11/23 01:57:44
    1A05B-2500-H551
    1A05B-2500-H521
    1A05B-2500-J684
    1A05B-2500-J765
    1A05B-2500-R663
    1A05B-2500-J567
    1A05B-2500-R784
    1A05B-2500-R650
    1A05B-2500-R694
    1A05B-2500-R809
    1A05B-2500-R850
    1A05B-2500-J541
    1A05B-2500-J878
    1A05B-2500-R843
    1A05B-2500-J873
    1A05B-2500-R848
    1A05B-2500-J945
    1A05B-2500-J946
    1A05B-2500-H746
    Z
    I try this, however the same advertisement appears on RG "The file backup requires version v8.23 wich is not installed. Run de FRVRC setup then try the operation again."
  • pdl
    266
    1,504
    • September 20, 2023 at 6:21 PM
    What is in C:\Program Files (x86)\FANUC\WinOLPC\Versions? (or wherever you installed RG)
    Also, I haven't tried this, but you may be able to edit frvirtual.exe. config to work with v8.23. That file can be found in C:\Program Files (x86)\FANUC\Shared\Off Line\FRVRC
  • ROBOT_G
    23
    241
    • September 21, 2023 at 6:40 PM
    Quote from pdl
    8.23 exist I actually have it in my roboguide. To be honest, not sure how.
  • retobor
    17
    202
    • September 21, 2023 at 7:03 PM
    Quote from ROBOT_G
    Yes, I have it aswell.
    Jose Eduardo Tlalpan have you tried reinstalling RG and selecting FRVRC V8.20 (or any other versions related to V8.2)?
  • pdl
    266
    1,504
    • September 21, 2023 at 7:35 PM
    Have you tried running it through WinOLPC instead of HandlingTool?
    • September 25, 2023 at 5:16 PM
    Quote from retobor
    Yes, I tried this but in the options I looked FRVRC V8.20, and FRVRC V8.30. I created a robot with 8.20 version with no results. Thank you for your support
    • October 6, 2023 at 10:28 PM
    • #11
    Quote from pdl
    Yep, I tried this without succes.
    • #12
    Quote from retobor
    I tried it also, I just have the 8.20 and 8.30 versions
  • #roboguide
  • #VAG
  • "FANUC
