Hello, how to please write this command on FLEXIPedant.
WHILE PNI_start_production=1 DO
to make it work?
(PNI_start_production is a digital input )
Thank you
to make it work?
Thank you
Take a look under Menu > Program Editor > Add Instruction.
! Do stuff
ENDWHILE
There is a function TestDI that you could use also.
While TestDI(PNI_start_production) DO
TEST PNI_choose_type (GI)
CASE 1:
IF PNI_start=1 THEN
Type_1;
ENDIF
CASE 2:
IF PNI_start=1 THEN
Type_2;
ENDIF
please how to write this Test case command on flexipedant?
I'am sorry but I really don't understand the problem. Try this:
! Do stuff
ENDWHILE
By the way, your code ist missing ENDTEST and ENDWHILE instructions. If you are not able to create the code with the FlexPendant, you can download RobotStudio and write your code there.
You need to go here and download the manual:
please how to simulate TEST PNI_choose_type ?
Teach pendant, I/O screen, Simulate option.
