Hello
I am using a program which is included with an external STOP key. The stop key goes into an interrupt and then BRAKE. After the problem is solved, the command RESUME is used to continue the work...
BUT
After Braking and then again RESUME, the robot will just go directly to the last point of the continues path and the other points and path in between are ignored. Based on user manual, I expected that it continues from the next point not the end of the path.
Can anyone help about the reason and how to solve it?
