I HAVE A KRC4/KRC4 COMPACT CONTROLLER AND I NEED THE PROFINET COMMUNICATIONS PACKAGE, CAN SOMEONE PROVIDE IT TO ME, THE KOP FILE
I need communications package for profinet KRC4
guillem alfaro -
April 17, 2023 at 10:53 AM -
95devils
April 17, 2023 at 11:59 AM Approved the thread. -
I do not think this is a free package. Talk to your local KUKA representative on how to buy it.
Btw. asking for software piracy will get you banned. Final warning!
Fubini
I need a third party page where they support kuka packages
what?
There are none. These packages are only available from KUKA.
You also need to determine which ProfiNet package you need -- there is the Device-only version, the Scanner&Device version, and the version which also includes ProfiSafe. Each of these has its own specific costs and benefits.
this kuka you mentioned is also referred to as an option package and is not offered for free. if you are connected to a robot via workvisual, if workvisual asks you to upload a ".kop" file, it is usually because workvisual does not have the configuration (.kop) file on the robot. Be admin on the robot, minimize hmi. Connect a USB stick, you will see the KRC_OPT folder in the d disk with the help of the on-screen keyboard. If there is a .kop file you need in it, take it and put it on the flash memory. When you upload it to workvisual, you will have the robot version on work visual.
