  4. ABB Robot Forum
Program in 2 steps
  • Matrixx
  • June 17, 2021 at 10:07 AM
  • Matrixx
    Hi
    We have a ABB welding robot on a track that can move between 2 stations and weld.
    The problem is that in one of the weld operation there is about 10 min waiting time because the operator have to manually instal and weld an object in between the welding operation.
    Is it possible to split the program in 2 so that the robot can move to the other station and weld while
    the operator is installing the object. And after the robot finishes the other station it comes and continues to finish the remaining program.
    Ex
    Proc WeldProgram();
    StartStn1;
    Program1;
    Program2;
    Program3;
    Program4;
    EndStn;
    EndProc;
    I want the program spilt into 2 steps so that it welds program1 and program2 in the first step.
    Then the robot moves to the other station and welds. After it finishes it comes back and welds Program3 and program4 in the 2 step.
    Thanks in advance.
  • Lemster68
    301
    2,485
    Blog Articles
    7
    • June 17, 2021 at 1:56 PM
    Of course you can. So long as you observe proper safety precautions. Is there another safety gate, light curtain, etc., to prevent the robot from striking the operator?
  • Matrixx
    • June 17, 2021 at 2:01 PM
    Thank you for the reply
    Yes all of the safety procedures are in place. Usually the robot automatically goes to the other station then the operator can enter and work.
    I want the robot to finish program1 and program2 and then go to the other station before the operator enters.
  • Matrixx
    • June 19, 2021 at 9:42 PM
    Is there someone out there who have a sugestion about how to do it. It will be greatly apreciated.
  • palmeida
    18
    • June 20, 2021 at 8:43 AM
    Quote from Matrixx
    Ex
    Proc WeldProgram();
    StartStn1;
    Program1;
    Program2;
    Program3;
    Program4;
    EndStn;
    EndProc;
    Thanks in advance.
    It seems like you exactly what you want to accomplish, look at the logic that calls the WeldProgram(), at the main() level or PLC, and you can decide the way it better suits you.
    For example:
    You split into WeldProgramStage1() and WeldProgramStage2() and a PLC calls the program.
    First the PLC calls WeldProgramStage1(), records that the first stage of the weld is done.
    Then PLC calls the program for the other station while the operator do the manual weld.
    Then PLC knowing that stage1 is done, manual weld is done now it calls WeldProgramStage2().
    Something like that.
  • SharplesR
    443
    • June 23, 2021 at 10:20 PM
    A possible structure, which would require setup with PLC input signals (here named "PLCinput1" and "PLCinput2").
    Ex
    Proc WeldProgram();
    StartStn1;
    IF PLCinput1 THEN
    Program1;
    Program2;
    ELSEIF PLCinput2 THEN
    Program3;
    Program4;
    END
    EndStn;
    EndProc;
Similar Threads
  • E1 Axis Velocity and Acc Not Progrmmed !!!
    • ravitejagali
    • June 15, 2021 at 12:52 PM
    • KUKA Robot Forum
  • How to log when "cancel waiting" has been pressed to bypass steps?
    • paul.switzer
    • June 14, 2021 at 9:21 AM
    • Kawasaki Robot Forum
  • Wait on input during motion?
    • n0909
    • June 1, 2021 at 10:39 AM
    • KUKA Robot Forum
  • ConveyorTech 8.0.1 (Linear External Conveyor)
    • iRoboti
    • June 4, 2021 at 12:09 AM
    • KUKA Robot Forum
  • KUKA controller C4 with KSI udp communication
    • ruiming hu
    • June 2, 2021 at 5:52 PM
    • KUKA Robot Forum
  • Example Robot Program
    • Dodo41
    • April 3, 2021 at 6:37 PM
    • ABB Robot Forum
  • Dividing Movements into Steps doesn't work
    • Mo_Sa
    • October 1, 2018 at 2:43 PM
    • KUKA Robot Forum
  • KUKA ROBOT
    • jjf
    • September 25, 2018 at 2:09 PM
    • KUKA Robot Forum
  • Programming ABB robot
