Hello, I need some information about writing a robot program.
My System;
IRB 2600 Robot
IRC 5 Controller
You may think I want to prepare an aluminum welding project.
The steps are as follows.
On the front surface, 4 areas will be welded.
Since these sources are in 4 different regions, should I create 4 routine files?
And since 4 different zones will go as Job 1-2-3-4 respectively, how should I direct the Robot to the 2nd zone after the 1st Zone is over?
After the front surface is completed!
The fixture will turn
It will weld a point on the back surface (Job 5), then to weld the 6th Zone respectively.
Robot will send a clamp open signal
The clamp will open
The robot will verify that the clamp has opened and then
The last point (Job 6) will be weld.
Then the clamp will close and the fixture will turn again.
