Tool info message
  • Mmmmm
  • March 30, 2021 at 9:41 PM
  • Mmmmm
    14
    I am getting a message which reads:
    "Using robot without setting tool info. may result in premature failure of the robot. Set W, Xg, Yg, and Zg in the tool file."
    The tool file does contain this information. Is there something I need to do to get this reset correctly? Any way to get rid of this message?
  • 95devils
    234
    8
    1,947
    • March 31, 2021 at 5:55 PM
    Do you have Tool No. Switch set to Permit or Prohibit?
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • March 31, 2021 at 5:59 PM
    You have not identified the tool load, You need to perform the measurement sequence. I forgot exactly what it is called, help me out, 95Devils, please. I suppose you know it right off the top of your head.
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • March 31, 2021 at 6:01 PM
    And, interestingly enough, it will greatly limit the speed at which it reorients. It makes sense, though, if it does not know mass or cog, it does not want to damage itself. It probably just moves at worse case full load speed.
  • rbtx-m1
    • March 31, 2021 at 6:57 PM
    There is a buit-in function to measure tool load and center of gravity. On the same menu that you access for tool TCP data, on the Utilities button therre is an W. GRAV. Measure option. This will have the robot measure the COG and Load of the tool by moving the wrist axis on the FWD /key. I think the full procedure is on any of the Operators manuals from Yaskawa. Tool Data setting sections.
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • March 31, 2021 at 7:12 PM
    Thank you for clarifying, I did not want to send on a wild goose chase by misnaming the function!
  • mihaita
    73
    • March 31, 2021 at 9:03 PM
    please the moderators to correct me if I am wrong but I think the solution is this: robot-tool-choose your tool number-select-data-reading-choose your tool-select.respect.
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • April 1, 2021 at 1:54 PM
    I cannot even understand what you are trying to say or describe.
  • Kushal Patel
    31
    • April 1, 2021 at 2:48 PM
    Quote from rbtx-m1
    This is right I have experienced same issue and same massage was popping on TP screen. After performing tool load and CG calibration it went away.
    But after few months it came back all the calibrated were there still same massage appear so I have done same thing again and after few months it comes back again and again.
    Is there anyone know permanent solution.
    PS:- Every time after calibration all value stays same.
  • rbtx-m1
    • April 1, 2021 at 7:15 PM
    I can only think of one reason why your tool data gets " lost". Are you loading a backup that might have that flag turned off? I know that there is a parameter that sets once you calibrate ( I don't have a name/number right now). I can't think of any reason why the controller would erase it periodically.
  • Mmmmm
    14
    • April 2, 2021 at 5:38 PM
    • #11
    Well, I got rid of the message. I'm still not sure why it was there in the first place since the tool data was always there. I finally just changed the data for "W", confirmed it and then changed it back.
  • Ro Bo Rye
    20
    • September 24, 2024 at 7:02 PM
    • #12
    We have several types of DX 200 Material Handling robots that give the same "Using Robot without setting Tool info" comment shown at top of this thread. All of our tool data, weight, center of gravity data is entered just fine. If you do the Weight/Gravity measurement again, the data stays the same but the comment does clear......coming back in a matter of days or weeks. Nothing to do with Backups being uploaded. We are proned to power outages here, could this cause some sort of reset glitch? Is there in fact a parameter that could be the issue? Looking for some ideas. thanx
    Cheers! :top:
Similar Threads
  • Yaskawa YRC1000 Alarm Codes 4740 and 4747 [1]
    • Cappy3892
    • December 29, 2020 at 8:04 PM
    • Yaskawa Motoman Robot Forum
  • hard wired approximation settings
    • MalcolmK
    • November 9, 2020 at 4:58 AM
    • KUKA Robot Forum
  • For sale KuKa Tool mastering calibration KRC4
    • olololo1986
    • July 6, 2020 at 3:11 PM
    • Used Robots and parts
  • Bulls Eye - BEToolNotFound after BESetupToolJ
    • Deniska
    • January 30, 2019 at 9:54 PM
    • ABB Robot Forum
  • tool shape points setup in robot pendant and cubic-s
    • superbei30
    • February 22, 2019 at 11:37 PM
    • Kawasaki Robot Forum
  • KRC2 startup errors - the robot won't move
    • vvelikov
    • November 11, 2013 at 3:47 PM
    • KUKA Robot Forum
  • Control in PLC the code line of the robot?
    • ctor
    • April 23, 2018 at 11:51 AM
    • Fanuc Robot Forum
