PDAT, LDAT, and FDAT Parameter Definitions
  • micahstuh
  • February 17, 2021 at 8:22 PM
  • micahstuh
    7
    31
    I can't figure out the shortened names for many of the parameters in these STRUCs. Can someone give a quick definition to each, or point out a reference document that describes them?
    STRUC PDAT REAL VEL,ACC,APO_DIST,APO_MODE_T APO_MODE,REAL GEAR_JERK
    STRUC LDAT REAL VEL,ACC,APO_DIST,APO_FAC,AXIS_VEL,AXIS_ACC,ORI_TYPE ORI_TYP,CIRC_TYPECIRC_TYP,REAL JERK_FAC,GEAR_JERK,INT EXAX_IGN,CIRC_MODE CB
    STRUC FDAT INT TOOL_NO,BASE_NO,IPO_MODE IPO_FRAME,CHAR POINT2[24],BOOL TQ_STATE
  • Go to Best Answer
    panic mode
    1,278
    13,079
    • February 17, 2021 at 9:37 PM
    can you be specific?
    highlighted ones are basic data types
    REAL = 32-bit number, floating point
    INT = 32-bit number, signed, integer
    BOOL = boolean (TRUE/FALSE)
    CHAR = character (8-bit)
    PDAT and LDAT are PTP and CP motion parameters, store motion parameters for inline form motion instructions (PDAT for PTP motions, LDAT for LIN and CIRC motions, because units are different)
    FDAT is Frame info for some point (tool, base etc)
    VEL = velocity (first derivative, dx/dt)
    ACC = acceleration (second derivative)
    JERK = jerk (third derivative)
    APO = approximation
    ORI = orientation
    TQ = Torque
    EXAX = external axis
    IPO = interpolation, IPO_MODE tells what frame is the reference frame (usually 'stationary')
    suffix _T and _TYPE indicate that this is TYPE of some sort (ENUM or STRUC)
  • micahstuh
    7
    31
    • February 18, 2021 at 4:23 PM
    I understand most of the parameters out of context, but some of these I can't figure out, such as:
    APO_FAC
    JERK_FAC
    GEAR_JERK
    EXAX_IGN
    CIRC_MODE
    POINT2[24]
    TQ_STATE
    Can you help shed some light on precisely what each of these parameters do? Maybe even some units where applicable?
    SkyeFire
    1,051
    9,423
    • February 18, 2021 at 4:55 PM
    Opening up BAS.SRC will show you exactly what the system does with these variables. Particularly, which system variables they get passed into.
    Several of these variables either don't get used for anything, are only used for particular special motion modes, or are obsolete but kept in order to maintain backwards compatibility.
    CIRC_MODE is a variable type -- the actual variable is CB.
    POINT1 and POINT2 are not part of LDAT or PDAT -- they're part of BASIS_SUGG_T, which is only used by the user interface to suggest new point names as you create new ILF points.
  • Fubini
    278
    1,886
    • February 18, 2021 at 4:56 PM
    Open bas.src lookup where these variables are used and figure out to what system variable (variables starting with $) and how they map. Afterwards lookup the system variables manual to understand it completely.
    Ok skyefire Beat me to it. 😂
    Fubini
  • micahstuh
    7
    31
    • February 19, 2021 at 12:57 PM
    Yeah forgive me. I understand the value of investigating, but in most programming languages it's bad practice to have functions, structures, classes, etc without documentation that is completely exhaustive. The system variables document is pretty good but I saw that these structures didn't make the cut.
  • hermann
    406
    2,609
    • February 19, 2021 at 1:18 PM
    • Best Answer
    Quote from micahstuh
    .. bad practice to have functions, structures, classes, etc without documentation..
    You are right, but those structures are used only in Inline forms and are filled with values from the input fields in the inlines.
    So Kuka employees seem to think it's not necessary to document them, I can understand that point of view.
    SkyeFire
    1,051
    9,423
    • February 19, 2021 at 2:37 PM
    There's a divide here -- system variables are an inherent part of KSS, and start with $. It's impossible to remove them from a KRC.
    But these variables are user-space variables that just happen to come by default with every robot -- they can actually be deleted entirely, without harming the operation of the robot. They are only used by the user interface, to support the Inline Forms. It's entirely possible to delete the entire contents of $CONFIG.DAT and still have an operable KRC, you'll just have to hand-program everything in KRL"raw".
    Documentation of these variables seems to fall into this divide -- the KSS engineers are pretty good about documenting the core system variables and functions (with a few, odd, glaring exceptions), but there seems to be an assumption that if you using Inline Form programming, you're working in "amateur mode" and don't need (or aren't interested in) any more detail. So the documentation seems to split into two categories: manuals for people who only use the menus and ILFs and never dig any deeper, and manuals for "real" programmers who do everything in raw KRL with a text editor.
    The good news here is that KUKA (unlike, say, Fanuc) exposes the entirety of $CONFIG.DAT, BAS.SRC, and the other "factory option" files (like IR_STOPM) to anyone willing to dig a bit, and the code is entirely open to being reverse-engineered and even modified.
  • micahstuh
    7
    31
    • February 19, 2021 at 2:51 PM
    Thank you all for clearing that up for me. I hadn't thought of that perspective before SkyFire, good point.
  • PDAT
  • LDAT
  • FDAT
