KRC4 X11 Safety
  • panic mode
  • January 22, 2021 at 2:45 PM
  • panic mode
    1,267
    13,033
    another one of PM:
    Quote
    I have most of my experience using Yaskawa however i'm now switching to Kuka.
    I have a KRC4 controller that I'm trying to add an external pendant (without a PLC) to control the robot in AUT.
    I have dual channel connections on X11 SIB Standard
    E-Stop 1 & 2 19 & 20
    Safety Curtain 3 & 4 21 & 22
    Acknowledge Operator Safety 5 &6 23 & 24
    and jumpers on the other X11 connections
    My plan is to use Automatic External for program start $EXT_START, enable drive on $MOVE_ENABLE and interface active $I_O_ACT
    I'm assuming i can select a program on the pendant and then run AUT from the pendant.
    Firstly is that path possible?
    Can you help me with the error i'm getting and can't seem to be cleared?
    Thanks for your help
    SkyeFire
    1,040
    9,380
    • January 22, 2021 at 2:51 PM
    Quote
    Not possible. AUT mode works only from the SmartPad, and is not compatible with the AUTO_EXTERN signals ($EXT_START, etc).
    If you want the robot to run without the SmartPad, your only option is to use EXT mode, and set up a Fieldbus I/O mapped to the AUTO_EXTERN signals.
  • panic mode
    1,267
    13,033
    • January 22, 2021 at 5:28 PM
    there is more than one variant of KRC4, what is the exact one that you are dealing with?
    because each of them can have X11 interface though pinout is different.
    download section contains X11 examples, check them out. when it comes to KUKA controllers, there are several circuits that need to be completed:
    EStop
    Operator safety (gate / curtain)
    Ack Operator safety
    Safety Stop1
    Safety Stop2
    External Enabling Switch
    your screenshot shows messages that could be result of miswiring (or the inputs are not ok)
    To use EXT mode, several things need to be done:
    CELL.SRC need to be completed (KUKA provides template)
    AutoExtern I/O need to be configured
    ack messages (some can only be acknowledged from smartPad)
    $I_O_ACT need to be active (usually always on, mapped to input 1025)
    move enable need to be on (controlled from PLC or whatever)
    drives must be also activated using external signals
    then messages (any remaining) need to be cleared also using external signal
    and then start need to be issued (also external signal)
    after configuration process is to have operator manually select CELL.SRC,
    clear messages, perform BCO, change mode to EXT and external signals need to take over and do the rest.
Similar Threads
  • How to use the Profisafe communication in TIA portal?
    • Koppel
    • December 11, 2019 at 4:13 PM
    • KUKA Robot Forum
  • Non-safe Siemens PLC controlling KRC4
    • Agustin Costa
    • October 26, 2020 at 1:21 PM
    • KUKA Robot Forum
  • Manipulating KUKA KRC4 safety bits with PLC with El6695-1001
    • iOdden
    • June 18, 2020 at 9:17 AM
    • KUKA Robot Forum
  • Safety outputs KRC4
    • AgainstGravity
    • June 27, 2020 at 12:01 AM
    • KUKA Robot Forum
  • Resetting safety on krc4
    • AutoCamden2020
    • March 11, 2020 at 12:43 PM
    • KUKA Robot Forum
  • Kuka safety setup
    • Ruddock984
    • December 20, 2019 at 2:45 PM
    • KUKA Robot Forum
  • KUKA Profisafe again..
    • michal nieznany
    • May 19, 2019 at 1:54 PM
    • KUKA Robot Forum
  • KUKA Safe without SIB
    • MrNico
    • April 5, 2019 at 7:16 PM
    • KUKA Robot Forum
  • KRC4 communicate to compact logix safety plc over ethernet
    • RoboG
    • October 10, 2018 at 3:31 PM
    • KUKA Robot Forum
Users Viewing This Thread
  • 1 Guest
