Error project WorkVisual
  • TheFatRat
  • September 3, 2020 at 5:37 AM
  • TheFatRat
    18
    I faced a problem when opening a new project. Opening sign WorkVisual on a smart pad. I chose a new project and pressed activate, after that the robot hang up for 30-40 minutes, I decided to turn it off and then start robot. After the launch, errors kss 01421 appeared. A red cross appeared under the WorkVisual sign and all projects disappeared, a message also appeared ”The installer project cannot be determined”. All other projects that could have been activated, including the initial one, have disappeared. Before activating a new project, I made a backup copy of the robot, after activating the activation about the impossibility of completely restoring the system.
    Who can help solve this problem?
    The problem occurred on the robot Kuka kr210 r2700 extra, KR C4, KSS version 8.2.20, WorkVisual version 3.1.
    Thanks for help.
    Images
      • 126.09 kB
      • 900 × 1,200
      • 51
    massula
    205
    8
    1,437
    • September 3, 2020 at 11:57 AM
    Well, these old KSS versions (8.2.17, 8.2.20,...) have some bugs regarding file corruption. But I will also put some bets on HDD integrity.
    So, at first, I would recommend You try to restore the last good WorkVisual active project. If not work, restore an HDD image, and after this, restore the project. If You still have problems, maybe try to swap the HDD.
  • panic mode
    1,294
    13,126
    • September 3, 2020 at 2:47 PM
    how exactly did you make the backup and restore? are the projects really in C:\KRC\User\ProjectRoot?
    can you make archive and check AMR file?
  • TheFatRat
    18
    • September 4, 2020 at 4:18 AM
    Quote from panic mode
    Backup File-Arhive-usb(cabinet)-All
    Restore File-Restore-USB (cabinet)-All
    Yes, the files WorkVisual are there. I do not know what is AMR file.
    I cannot delete the old project WV message error «an unspecified error occurred» when do recovering.
    Edited once, last by TheFatRat (September 4, 2020 at 5:24 AM).
  • TheFatRat
    18
    • September 4, 2020 at 8:24 AM
    I was able to restore the system, but the projects WV did not appear. WorkVisual on PC sees the robot, but I cannot upload any project.
    Images
      • 111.48 kB
      • 900 × 1,200
      • 19
  • panic mode
    1,294
    13,126
    • September 4, 2020 at 8:36 AM
    Quote from TheFatRat
    so the backup method is Kuka Archive
    Quote
    did you collect archive and look inside? there are several of them inside registry folder. one of them is named after workvisual, this one tells which of projects is a working project. does the reference exists and does it point at real project file? i guess not judging from your screenshots
    Quote
    KSS plugin is not working, something is corrupt in KSS or Windows or both.
  • TheFatRat
    18
    • September 4, 2020 at 10:27 AM
    так что метод резервного копирования - Kuka Archive
    ты собрал архив и заглянул внутрь? их несколько в папке реестра. один из них назван в честь workvisual, этот говорит, какой из проектов является рабочим. существует ли ссылка и указывает ли она на настоящий файл проекта? думаю не судя по твоим скриншотам
    Плагин KSS не работает, что-то повреждено в KSS или Windows, или в обоих.
    Is it possible to specify the link manually?
  • panic mode
    1,294
    13,126
    • September 4, 2020 at 10:38 AM
    what link?
    Images
      • 36.7 kB
      • 804 × 313
      • 17
  • TheFatRat
    18
    • September 4, 2020 at 10:47 AM
    what link?
    Yes, the link points to an existing project, can I change the name to another project and will this work?
Similar Threads
  • KukaSim and OfficeLite
    • robocoder
    • August 16, 2020 at 6:49 PM
    • KUKA Robot Forum
  • KR C4 WorkVisual 4.0 Deploy Error
    • DurmazOnur
    • September 30, 2018 at 12:10 PM
    • KUKA Robot Forum
  • How to reset KRC4 controller without wiping programs?
    • tsui0620
    • May 14, 2018 at 1:46 PM
    • KUKA Robot Forum
  • KSS reinstallation
    • spukhov
    • December 22, 2017 at 1:31 PM
    • KUKA Robot Forum
  • Failed to deploy on Agilus
    • Tali
    • April 12, 2017 at 4:41 PM
    • KUKA Robot Forum
  • Problem transfering project from Robot to PC
    • robot_newbie_101
    • February 6, 2017 at 6:07 PM
    • KUKA Robot Forum
  • Project activation catastrophic failure
    • loic63
    • February 8, 2017 at 5:32 PM
    • KUKA Robot Forum
  • Workvisual 4.0 error
    • s.yilmaz
    • November 28, 2016 at 9:53 AM
    • KUKA Robot Forum
