KSS 8.3.17
Okay, I'm a bit stumped. I keep getting this error inconsistently -- it seems to happen randomly, at different lines of code (including unmodified PTP/LIN ILFs). The real kicker, though, is that whatever line the program pointer stops on when this error pops, there's no variable named "ID". In fact, I don't have any variables with that name anywhere in the entire .SRC or .DAT file. Heck, one of the times this error popped, it was on the LIN XPointName command inside an ILF, and the point name existed in the .DAT file, was valid (I checked with the VarCor), and doesn't have "ID" anywhere in its name.
I'm running with the program directly selected in T1, the "source" part of the error message matches that program name, and there's nothing named "ID" in the SPS either.
The only clue is that it only seems to happen if I've recently done a Block Select somewhere in the program.
And I just ran a dozen cycles in full auto without any issues whatsoever, without changing the code at all. Anyone ever see anything like this?
