KLI Interface Problems
  • dhracer3
  • August 25, 2020 at 4:13 AM
  • dhracer3
    So I'm trying to connect 2 of our smaller robots in the plant here to our network.
    Both robots are running the KRC4 Compact controller. One robot is a KR3 and the other a KR6
    None of them run Profinet. All run on Profibus. I have searched both the forums, through Kuka Xpert, Manuals and the commisioning manuals.
    Both robots are running 8.3 one is on 8.3.37 and the other on 8.3.14
    using WV6.0 but have also tried using WV5.0
    From what I can gather this shouldn't be to hard to do.
    You go to the startup - network and then you can change your KLI to a static IP and make sure it matches your companies network.
    Ive also tried looking at the NAT ports. Manual says the 49xxx ports are for windows and connecting to Work visual.
    I have the check box on the Virtual5 network checked for the windows interface.
    I then Save everything and it tells me to reboot with reload files.
    When I reboot the RC everything seems fine.
    When I plug into the network I start getting SYS X44 PB slave errors.
    To me this looks like the network is trying to reconfigure my PB slaves like I'm setup for Profinet? Is this a Port Issue?
    I can't seem to find an answer anywhere and I'm wondering is there something I'm just missing that is obvious?
    Ive read through at least 3 manuals that shows how to configure the KLI so that we can make program changes through the network but nothing explains why I'm having Profibus issues after I connect the KLI up.
    Images
      • 317.12 kB
      • 1,562 × 1,200
      • 37
  • dhracer3
    • August 25, 2020 at 4:14 AM
    Network setting
    Images
      • 150.06 kB
      • 921 × 1,200
      • 71
  • MOM
    176
    7
    1,424
    • August 25, 2020 at 9:30 AM
    the first thing I see your subnet mask is wrong
    IP Address starting with 10 means Class A network and therefore subnet mask 255.0.0.0
    regards
    MOM
  • panic mode
    1,296
    13,133
    • August 25, 2020 at 3:11 PM
    Hmmm... that makes no sense... you want to connect two robots to a plant network? what kind of plant network? for what purpose? what kind of data exchange?
    making any type of setting changes to KLI has no effect on operation of KEB, they are not related at all.
    are you sure you connected network cables to a correct port on your controller? did you read controller schematics?
    on compact controller, KLI is on port X66, next to power switch.
    outcome you describe suggest that you connected the network cable to KEB (X65) instead of KLI (X66). this is why you see problems related to X44.
    it is important to pay attention what is connected to what, not merely try to plug into first thing that fits. I hope following clarifies it:
  • dhracer3
    • August 26, 2020 at 1:19 AM
    I don't know how but completely missed the port by the power switch. Somehow got it in my head that the port next to KSI was the KLI.
    Sorry for wasting your time.
    I knew there was something weird going on when my KEB was giving me errors.
    Thanks for the help.
Similar Threads
  • Access Y200 interface in OfficeLite
    • Mischa
    • July 29, 2019 at 3:28 PM
    • KUKA Robot Forum
  • HIBERNATE - IS IT A PROBLEM FOR KRC4?
    • IlFincoITA
    • June 8, 2020 at 1:01 PM
    • KUKA Robot Forum
  • KRC4 and $meas_puls[1]. Who knows the pins of X23 and X25?
    • Henry Sheppard
    • June 19, 2020 at 11:16 AM
    • KUKA Robot Forum
  • Problem in interfacing KUKA SIMPRO and KUKA Office Lite
    • Sarmad
    • April 8, 2019 at 11:04 AM
    • KUKA Robot Forum
  • KRC1 - Sudden Drive Enable problems
    • maaron
    • July 2, 2019 at 11:59 PM
    • KUKA Robot Forum
  • smartPAD communication (and other) problems
    • masant
    • March 26, 2018 at 8:02 PM
    • KUKA Robot Forum
  • start-up mode,KRC4
    • ak
    • April 7, 2015 at 9:49 AM
    • KUKA Robot Forum
  • Problems - EthernetIP communication between KUKA KR sixx Agilus and Rockwell PLC
    • masant
    • September 29, 2016 at 3:08 PM
    • KUKA Robot Forum
  • Fanuc R-30iB Ethernet/IP Welding Interface
    • tp123
    • July 14, 2016 at 5:10 AM
    • Fanuc Robot Forum
  • Problems with x11 interface (AUT mode)
    • masant
    • July 15, 2016 at 4:09 PM
    • KUKA Robot Forum
  • KLI
