Hi folks - maaron here again, unfortunately I bear questions and a problem. Please note that software and build versions are forthcoming, I need to get back out to the floor to get them, however I suspect this is not a software-related problem.
To give some context, I'm running a set of GM Kuka KRC1 K150 frame robots on a production line. One is for occasional R&D, the other is (or rather was) in full production. It has been running without major issue for quite some time now, almost a year at this point.
According to the fault log on the controller, the robot came to an emergency stop toward the end of the second shift yesterday evening, and I have been unable to get it to move since. drives are not able to be enabled in EXT as they once were, and the deadman switch does not work in T1 or T2 to manually move the arm either.
Jumpers for the CC1 plug have not been changed, but I have tightened them to ensure a good connection. No errors occur that would suggest this as my main problem, only the "active commands inhibited" message.
A look in the cabinet shows a set of the LEDs on the main safety board (FE207?) are not lit. The picture attached shows what I'm looking at without any buttons pressed in T1/T2. In EXT pushing the drives on button on the KCP only toggles one small relay (V56) and does not lock in any other of the larger relays. I have gone so far as to swap the safety cards (both 207 and 208) with our parts robot and I am still experiencing the same symptoms.
TLDR:
KRC1 isn't enabling drives. The configuration has been working flawlessly to this point. Looking at the picture attached can someone verify that one or more of the LEDS that are not lit indeed should be lit? I'm perusing the wiring diagrams that came with the cabinet, and I'm having trouble pinpointing where I should be checking for power/continuity/etc. to determine if it's relays or wiring or something else entirely that is causing my problem. Any clues or leads are greatly appreciated.
