  3. Cobot Help and Discussion Center
  4. KUKA LBR IIWA
Test LBR Axis in real time
  • amex
  • November 5, 2019 at 2:47 PM
  • amex
    24
    I am new here and a junior in robotic world.
    I have Kuka LBR Robot with KR C2 controller. I start the controller all load but want to ask you how I can test each axis of the robot in real time to check if it work properly? Can I have make and selftest to check the condition of the robot if it work properly?
    Thank you in advance!
    Best regads
  • SkyeFire November 5, 2019 at 2:52 PM
    Moved the thread from forum KUKA Robot Forum to forum KUKA LBR IIWA.
    SkyeFire
    1,039
    9,380
    • November 5, 2019 at 2:53 PM
    "Test in real time"? What do you mean?
  • amex
    24
    • November 5, 2019 at 3:05 PM
    I want for example with the joystick in the right side of the control panel or with the keys on the panel to move each axis in real time manually.
    SkyeFire
    1,039
    9,380
    • November 5, 2019 at 3:14 PM
    You just want to jog the robot? That's simple, just squeeze the deadman enabler and use the Space Mouse or the jogging keys.
  • amex
    24
    • November 5, 2019 at 3:16 PM
    Yes but how to do it? I'm new in the robotic world :smiling_face:
    SkyeFire
    1,039
    9,380
    • November 5, 2019 at 3:50 PM
    "How do I fix my car?"
    That's the equivalent of the question you've just asked.
    First: read the manual that came with the robot. Or look in the Manuals sub-forum.
  • amex
    24
    • November 5, 2019 at 3:53 PM
    In Status window is following information:
    ! 3:59:38 PM 6503 Configuration error I/О driver DN2DRV
    ! 3:59:41 PM 4 Buffer battery voltage low PM1
    ! 4:00:24 Pm 420 KS Local Protective Stop (QE)
    ! 4:00:24 PM 1 KS EMERGENCY STOP
    ! 4:00:24 PM 20 KS External EMERGENCY STOP Pressed
    ! 4:00:24 PM 404 KS EMERGENCY STOP safety controller
    ! 4:00:24 PM 310 KS Safety circuit for driver not ready
    ! 4:00:24 PM 200 KS Drives contactor off
    ! 4:00:24 PM 1034 Error or writting, driver DN2DRV
    ! 4:00:24 PM 482 LR LR: Position-Control
    ! 4:00:25 PM 364 KS unknown Operation Mode (?)
  • amex
    24
    • November 7, 2019 at 6:36 PM
    Hello again,
    I have read the Kuka instructions and documentation. I have the following error codes when I start the Kuka:
    ! 3:59:41 PM 4 Buffer battery voltage low PM1 <- I have replace the both akku's and now do not show me this error [DONE]
    The bolded error codes for the emergency afraid me but I have read the documentation and then is written that I must connect the emergency switch to connector X11. I have with bridge cables simulate the emergency connector as follow:
    Connector X11:
    bridge between Pin1 and Pin20
    bridge between Pin2 and Pin21
    bridge between Pin3 and Pin24
    bridge between Pin4 and pin25
    but without result
    I have connect and external 24V power supply on the same connector X11 on:
    Pin15 and Pin16 - Ground
    Pin33 and Pin34 - 24V supply
    but again without result
    Want to ask you is it possible that this emergency stop to be a software settings or I make some wrong?
    I think that when all this error codes was removed will have the possibility to jog the robot.
    Best regards
  • amex
    24
    • November 8, 2019 at 8:19 AM
    Hello Guys,
    I have not answer from you with ideas and issues of my problem with kuka emergency protection and today will try to simulate all possible emergency signals to try to jog the robot.
    To simulate the hardware emergency protection will use the following wiring diagram for connector X11 from the kuka kr c2 dokumentaion.
    If you have other ideas please write me.
    Images
      • 85.97 kB
      • 557 × 650
      • 21
    SkyeFire
    1,039
    9,380
    • November 8, 2019 at 4:27 PM
    The "Unknown Operation Mode" error means that the safety board inside the KRC is not getting any power.
    Do you have the 0V and 24V jumpers on X11? Check for voltage between those pairs.
  • amex
    24
    • November 8, 2019 at 4:31 PM
    • #11
    Hi SkyeFire,
    Thank you for your reply
    We have not supply voltage between Pin37 - 0V ESC and Pin19 - 24V ESC - we messured by power on 0V between this two pin on connector X11
    SkyeFire
    1,039
    9,380
    • November 8, 2019 at 4:33 PM
    • #12
    That suggests you have a power supply issue internal to the robot.
    However, the LBR is a sufficiently unique system that just using the KRC2 rules/jumpers may not work. I think you may need to contact KUKA tech support on this one.
  • amex
    24
    • November 8, 2019 at 4:40 PM
    • #13
    You think that the problem is in the robot (arm manipulator) or in the Robot control box where is the PC, UPS, ESC and other component for control the robot.
  • amex
    24
    • November 8, 2019 at 6:21 PM
    • #14
    Its two different wiring diagrams for internal power supply and external on KR C2.
    My controller is: "Type: LC Controller" - is written on the label
    I have try with internal power supply (by me on Pin19 and Pin37 have not 24V) and with external 24V power supply - the result is the same with the same errors.
    I attach the wiring diagrams
    Images
      • 160.87 kB
      • 1,092 × 650
      • 27
  • amex
    24
    • November 9, 2019 at 1:19 PM
    • #15
    I have found the right documentation with right pinout and wiring diagrams for my controller.
    Now I have good result - the EMERGENCY mode now work and the ESC Controller have supply now I can diagnose.
    I have other error in status windows that I can not understand where is the problem. I have read all documentation but can not find the needed information. Also the error codes are:
    6503 Configuration error I/O driver DN2DRV
    310 KS Safety circuit for drives not ready
    1034 Error on writing, driver: DN2DRV
    482 LR LR:Porigion-Control
    This error that are bold marked can not fin information.
  • hiimtom
    5
    19
    • November 10, 2019 at 9:36 PM
    • #16
    The LBR uses a the Sunrise controller, not the KRC2.
    How exactly have you plugged in the robot?
    SkyeFire
    1,039
    9,380
    • November 11, 2019 at 2:54 AM
    • #17
    The "Drives contactor off" is not an error, just a status. When you enable the deadman, that error should go away as the motors energize.
    The "Safety Circuit not ready" message is odd -- I would expect that to happen alongside an E-Stop or Motion Enable error.
    The "Porigion" error I'm not familiar with.
    The DNDRV error could be related to your motion issue -- check the setting of $MOVE_ENABLE. You may need to change it to 1025 (the "always true" input) until you have your external I/O working.
  • flame
    5
    • February 9, 2022 at 8:30 PM
    • #18
    I am trying to jog a lbr med 14 with the 6D mouse. When holding in the button I can jog using the buttons on the smartpad, but there is no option for the mouse. After digging I found a warning saying "Illegal 6D mouse position. 6D mouse is not activated. Reading data is not possible" I've tried to find documentation on activating the mouse but have not had luck. Currently using Sunrise.OS Med 1.15 V1
  • Cwany
    53
    • February 10, 2022 at 2:42 AM
    • #19
    Quote from flame
    The 6D mouse is deactivated for LBR iiwa's. You cannot use it.
    I am not aware of any way to enabled it, or any one who was able to do so.
Similar Threads
  • FANUC PROJECT: Data recording with background Karel program
    • Axillus
    • August 12, 2019 at 5:56 PM
    • Fanuc Robot Forum
  • Jt1 System Axis Limits
    • kwakisaki
    • October 9, 2019 at 6:37 PM
    • Fanuc Robot Forum
  • Program with massive number of programmed motions/locations
    • tlambrop
    • November 7, 2016 at 9:04 PM
    • KUKA Robot Forum
  • ABB S4C+ Controller || Error 50056
    • robomaniac
    • August 13, 2018 at 9:53 PM
    • ABB Robot Forum
  • KRC I/O methods
    • SkyeFire
    • December 19, 2014 at 6:31 PM
    • KUKA Robot Forum
  • Placing with different orientations
    • atomic_robo
    • June 7, 2018 at 2:18 PM
    • KUKA Robot Forum
  • moving the robot (six axes) with laptop (3D software) to PLC to robot
    • sudan
    • March 16, 2018 at 2:19 PM
    • KUKA Robot Forum
  • Work envelope exceeded with RSI Ethernet XML
    • quanyx
    • November 8, 2016 at 1:32 PM
    • KUKA Robot Forum
  • DCS Setup
    • ESIELI
    • February 16, 2016 at 9:59 PM
    • Fanuc Robot Forum
