Hello All
Our SmartPad USB dosen't work from the first day we run the robot, Is there any way to fix it?
Any ideas are so appreciated.
Controller: KRC4 KSS 8.3
Hello All
Did you read pinned topic 'read first'?
You need to provide details on how exactly it 'does not work'....
Did you confirm that your usb keyboard works on other computers?
If you are trying to use it for file transfer, forget it - at least on KSS8.3. Kuka removed drivers for most of them. If you find usb stick that works (there are few), you found a unucorn. It will still be slow as molasses.... Better just use ports on controller.
Other KSS versions like 8.2 and 8 5 do support any usb stick at smartPad, as long as they are formated FAT. smartPad runs WinCE so NTFS is not available.
Controller runs Win7 so both FAT and NTFS are supported.
Think it was turned off on later versions of 8.3
As it's shockingly slow to use v8.5 this has been fixed I believe
