I have two Kuka KRC4 with a KR16 robots and one Kuka SmartPad.
The problem is with the SmartPad. It works fine with one control cabinet but when I use the SmartPad with the other control cabinet I get some communication errors and the SmartPad never finishes the boot up.
I suspect the RDP IP addresses are different between the two control cabinets but how do I verify this and also change the IP address on the SmartPad to work on both control cabinets?
Kuka KRC4 SmartPad RDP connection
rsofronici -
March 22, 2018 at 1:16 PM -
You don't. The IP address of the pad is set by the DHCP server in the robot. This allows pads to be swapped seamlessly between KRCs without any issues. If your smartpad won't connect to one KRC, that suggests the KRC is not booting properly. Have you tried Virtual Pendant from a computer connected to the KLI?
Are these brand-new robots, or were they working properly before?
