Fanuc robot testing
  • Dalin
  • May 14, 2019 at 4:46 PM
  • Dalin
    We bought a used robot and are trying to see everythin is righ...im used to kawasaki and is new to fanuc......when i start the robot and try to jog, it saays : 'bad io assgn ; rack 89 slot2;....." and doesnt move at all,.....can you help me figure this out please....
    Nation
    Typical Robot Error
    529
    1,910
    • May 14, 2019 at 5:22 PM
    Bad IO just means it can't see something on it's IO side. In this case the second device defined in the Ethernet IP menu. This shouldn't keep you from jogging though.
    See what alarms you have active in the alarm menu (menu->4).
    Next you would probably need to disable UOPS (menu->next->config), and make sure all the safety circuits are complete.
  • Dalin
    • May 15, 2019 at 3:42 PM
    errors srvo-223 and srvo-058 comes up and the red led SVEMG led on the board is lit right from the start...
  • TitusLepic
    112
    442
    • May 15, 2019 at 5:16 PM
    srvo-223 is a symptom of srvo-058. Here's the troubleshooting steps for the srvo-058:
    SRVO–058 FSSB init error (Group : i Axis : j)
    (Explanation)
    Communication was interrupted between the main
    board and servo amplifier.
    (Action 1)
    Check whether fuse F3 in the power supply unit has
    blown.
    (Action 2)
    Turn off the power and disconnect the CRF7
    connector on the servo amplifier. Then turn on the
    power and check whether this alarm occurs again.
    (Ignore the alarm SRVO–068 because of
    disconnecting the CRF7 connector.) If this alarm
    does not occur, the RP1 cable of the robot connection
    cable or the internal cable of the robot may be
    short–circuited to the ground. Check the cables and
    replace it if necessary.
    (Action 3)
    Check whether the LED (P5V and P3.3V) on the servo
    amplifier is lit. If they are not lit, the DC power is not
    supplied to the servo amplifier. Make sure the
    connector CP6 and CRM67 on the E–stop unit and the
    connector CRM67 on the servo amplifier are connected
    tightly. If they are connected tightly, replace the servo
    amplifier.
    (Action 4)
    Check the communication cable (optical fiber)
    between the main board and servo amplifier. Replace
    it if it is faulty.
    (Action 5)
    Replace the axis control card on the main board.
    (Action 6)
    Replace the servo amplifier.
    (Action 7)
    If the other units (the servo amplifier for the auxiliary
    axis and the line tracking interface) are connected in
    the FSSB optical communication, disconnect these
    units and connect only the 6–channel servo amplifier
    for the robot. Then turn on the power. If this alarm
    does not occur, search the failed unit and replace it.
    Before continuing to the next step, perform a complete controller
    back–up to save all your programs and settings. Failure to perform
    this could result in damage to equipment or lost data.
    (Action :smiling_face_with_sunglasses:
    Replace the main board.
  • Dalin
    • May 15, 2019 at 6:40 PM
    thanks for replyin.....
    -the fuses FS1,FS2,FS3, FUSE1,FUSE2, works right......
    -there Is port CFR8 instead of CFR7 and when i start the robot controller after disconnecting it , no alarm pops up; it still says just SRVO 223 and SRVO058
    -the SVEMG led is lit red always even if i push/release the e-stop on the controller
    -the OPEN led led is not lit at all anytime
    -the ALARM led is not lit at all, eventhough it shows thers alarm showin on the TP
    -i pulled out the optical fibre comm cable and restarted ; still says the same error
    :help: :help: :help:
  • brianb
    19
    • July 30, 2019 at 8:54 PM
    Quote from Dalin
    I have the same issues as quoted above on a brand new LR Mate (R30iB+). Nothing looks out of the ordinary and I checked my fuses. Robot has not moved yet and the software was just installed as well.
    Any help on this would be greatly appreciated!
  • SHIFT_Lock
    29
    237
    • July 30, 2019 at 9:11 PM
    Does it give you a specific Group and Axes number with the alarm? I know you said it's brand new but was the software loaded perhaps for an extended axes and you only have 6?
    "I could tell that my parents hated me. My bath toys were a toaster and a radio."
  • brianb
    19
    • July 31, 2019 at 1:14 PM
    My alarm screen is displaying:
    SRVO-223 DSP dry run (9,1)
    SRVO-058 FSSB 1 init error (2)
    Just an FYI, this cell consists of 3 LR Mates with the same software packages. The other two arms had no issues with the software load.
    Also, is it worth reloading software?
  • SHIFT_Lock
    29
    237
    • August 1, 2019 at 1:49 AM
    SRVO-223 DSP dry run (%d,%d)
    Cause: A servo DSP initialization failure occurred due to hardware failure or wrong software setting. Then, the software
    entered DSP dry run mode. The first number indicates the cause of the failure. The second number is extra
    information.
    Remedy: Perform an action according to the first number that is displayed in the alarm message.
    1: This is a warning due to $SCR.$STARTUP_CND=12.
    2,3,4,7: Replace a servo card.
    5: Invalid ATR setting. Software axis config (FSSB line number, hardware start axis number, amplifier number, and
    amplifier type) might be wrong.
    6: SRVO-180 occurs simultaneously. Controllable axis does not exist on any group. Execute aux axis setting to add
    axis at controlled start.
    8,10: SRVO-058 (FSSB init error) occurs simultaneously. Follow the remedy of SRVO-058.
    9: There is no amplifier that is connected to the servo card.
    • Check the hardware connection.
    • Check the optical fiber cable.
    • Check whether the servo am plifier power is supplied.
    • Check whether the fuse on the servo amplifier has blown.
    • Replace the optical fiber cable.
    • Replace the servo amplifier.
    11: Invalid axisorder setting. Non-existing axis number is specified. Software axis config (FSSB line number) might be
    wrong or auxiliary axis board is necessary.
    12: SRVO-059 (Servo amp init error) occurs simultaneously. Follow the remedy of SRVO-059.
    13,14,15: Document the events that led to the error, and contact your FANUC technical representative.
  • brianb
    19
    • August 1, 2019 at 5:02 PM
    We swapped out the optical cable that goes from the amplifier to the backplane and that resolved our issue...
  • Gabriel Maughan
    • February 9, 2020 at 2:00 PM
    • #11
    Just to add to above posts. We had a very similar issue:
    Also P3.3V wasn't lit.
    Turned out to be a dodgy cable in the robot loom.
  • saberlars
    Robot, beyond Human..
    22
    225
    • February 10, 2020 at 9:00 AM
    • #12
    Quote from Dalin
    1. Press I/O
    2. F1 [TYPE], 7 UOP
    3. F2 [CONFIG]
    4. Remove Rack, Slot, Start, Point value
    5. F1 [TYPE], 3 DIGITAL
    6. as same Step 4
    5. Controller Warm or Cold Start
    ABB, FANUC, Hyundai, Kawasaki
  • SamsamTheMaintMan
    • May 1, 2023 at 2:46 PM
    • #13
    Just, FYI. Servo 058 comes up on our robots often when the ACC are set too high. Operators like to speed up (200). I usually adjust to 125 and runs fine.
