KUKA HDD
  • Robotmei
  • July 7, 2018 at 2:31 PM
  • Robotmei
    203
    Hello dear users,
    I would like to know is there any difference between KUKA hard disk drives with a typical HDD?
    Thank you
  • Event Robotics
    8
    62
    • July 7, 2018 at 2:38 PM
    None.
    Only the price.
  • Robotmei
    203
    • July 8, 2018 at 7:01 AM
    Thanks for reply
    our KUKA HDD had problem so have bought 3 typical HDD (not from KUKA) and restored kuka Image on them, but controller didn't detect any of them. what can be the reason?
  • Spirit532
    178
    • July 8, 2018 at 12:21 PM
    If it's an IDE hard drive, check the manual mode jumpers and make sure they match the original.
  • hermann
    411
    2,621
    • July 8, 2018 at 1:32 PM
    Which controller? Krc1, krc2 ..?
    Is a CD Rom installed?
    What's the capacity of the hdds?
    On old controllers big hdds make trouble. Then you have to set the parameters in bios manually.And sometimes you have to set some jumpers on the hdd.
  • SkyeFire
    1,060
    9,456
    • July 8, 2018 at 7:01 PM
    Also, most newer controllers use solid-state drives (SSDs) instead of HDDs. And KRC4s use SATA rather than IDE.
  • Event Robotics
    8
    62
    • July 9, 2018 at 10:32 AM
    If you are using a KRC2 controller these work fine. (see picture)
    We had some problems with the cloning software, ghost 11 works fine.
    Make sure you format them before you put the image on it.
    Rick
    Images
      • 156 kB
      • 1,229 × 1,500
      • 83
    Files
    image.jpg_thumb 20.29 kB – 296 Downloads
  • Robotmei
    203
    • July 10, 2018 at 7:37 AM
    thanks for the answers,
    I have VKRC2 controller and it had 20GB western digit IDE HDD, i replaced it with a 40GB HDD for some reason, unfortunately controller can't detect new HDD.
    is there any way to figure out the problem?
  • Spirit532
    178
    • July 10, 2018 at 8:44 AM
    Quote from Robotmey
    You were literally told how to figure out the problem in the answers.
  • Robotmei
    203
    • July 10, 2018 at 8:52 AM
    I restored an Image of another HDD with 40GB capacity
  • Event Robotics
    8
    62
    • July 10, 2018 at 2:29 PM
    • #11
    If you connect the new disk to a pc does it show up in windows explorer??
    Rick
  • the leg
    643
    • July 10, 2018 at 10:34 PM
    • #12
    did you detect the hdd in the bios ?
  • uberdoom
    97
    • July 11, 2018 at 3:36 AM
    • #13
    If you haven't formatted it, it won't be detected. If it's ssd, some older KRC2s won't detect. Best way if the other drive is still functioning is to clone the original onto modern computer and restore that drive to new hd. Programs such as acronis do this very well. It will format your new drive exactly as the old one. When computer boots up connected to new hard drive enter into bios and detect new hd. You'll have to figure that out specific to your bios. It will detect one way or another but setting the right hd parameters will make it run much faster. Save and boot. Enjoy your new hd with a solid back up if anything else goes wrong.
  • Dumidan
    10
    • July 11, 2018 at 7:32 AM
    • #14
    Quote from Event Robotics
    Rick
    Did you use Gost on the KRC2 or did you extract the disk?
    My KRC2 ed05 has no CD and i am thinking to install some old ide CD and try it a boot
  • Event Robotics
    8
    62
    • July 11, 2018 at 8:39 AM
    • #15
    No i use ghost 11 or some other cloning software on a seperate pc.
    Create an image from the existing hdd and put it on the new one.
    So yes, take out the disk from the controller.
    Rick
    Edited once, last by Event Robotics (July 11, 2018 at 8:42 AM).
  • Robotmei
    203
    • July 11, 2018 at 7:24 PM
    • #16
    Quote from the leg
    PC can't detect new HDD, I think i should set some parameters on Bios setting , but I don't know how
  • Robotmei
    203
    • July 11, 2018 at 7:43 PM
    • #17
    Unfortunately PC can't detect my new HDD,
    I think as Hermann said i should set some parameters on bios setting, but how and where?
    does anybody idea?
  • uberdoom
    97
    • July 12, 2018 at 2:45 AM
    • #18
    lots of people have ideas...what's your motherboard and bios? they are all different.
  • AndrewWang
    63
    • July 12, 2018 at 6:46 AM
    • #19
    This is a normal HDD .From KUKA C2 series on, we have been in use of the software -Acronis for image backup and restore.With this software, we have never met up with blue or black screen with it, however GHOST did.
  • info555
    • May 1, 2021 at 2:15 PM
    • #20
