Our KUKA bot often request mastering. That happens when he is shut down on main switch or in any other situation
when he is off voltage. Batteries are OK . Can any one tell me what could be problem?
Losing mastering
branislav1991 -
March 26, 2018 at 11:33 AM -
it would be much more productive if you included some details. simply saying "it is a KUKA" does not really convey any details...
but you can try checking for blown fuses, message logs etc. probably it is RDC (the old one - RDC1) but could also be KPS600. -
I see you say that the batteries are good, I had the same issue but mine were bad batteries, after I replace the CMOS battery and the Kuka 12V batteries in the cabinets the mastering stays.
Hi
I had the same problem KRC16 losing mastering on Axis 3, the Problem was that encoder Harness on axis 3 was damaged .
Regards -
I just found out if I do a cold restart or the computer crashed I have to remaster the robot, not sure if its normal cause
I'm new to the robot world, trying to learn. -
Most likely the batteries are dead and require replacement.
Last year I had Agilus robot (installed earlier) had problem with losing its mastering on normal operation. After firmware update problem is solved.
We had KUKA Support helping us. -
Hi ,
Could you update us with the repair . what kuka done to sort out the problem ??
Cheers
as noted, they carried out firmware update. firmware is software that is not installed on HDD, it is stored and runs inside hardware components (such as RDC, KPP, KSP, CCU).
but to help anyone... ever... first thing it to identify type of system. architecture is very different for KRC1, KRC2 and KRC4. this is why READ FIRST topic is created and pinned for all to see but so many fail to heed...
