Bas Function
  • MissM
  • January 19, 2017 at 12:05 AM
  • MissM
    Hello everyone,
    I am new to Kuka robots (but have worked with Fanuc and ABB a lot) and I am trying to understand the BAS function (on KRC4). I know i can use it for TOOL and BASE setting, but I saw it was used for other things also. So my question is : What are all the other things BAS function can be used for ? And what is exaclty the purpose of this function ? I've got trough the programming manuals I have but haven't found any mention of it, any idea where else I could find the info ?
    Thanks for your help!
  • panic mode
    1,297
    13,141
    • January 19, 2017 at 4:21 AM
    BAS.SRC is just a text file, it can be read as is...
    SkyeFire
    1,061
    9,463
    • January 19, 2017 at 4:58 PM
    BAS isn't terribly special -- it's just some KRL code written to assist the "easy mode" menu-driven teach pendant programming. If you open it in a text editor, as Panic said, it's guts are completely exposed. Long story short, it's an easy-mode method for setting your active Tool, Base, Velocity, Accel, and other motion parameters on the fly. If you create a point on the pendant, a call to BAS gets inserted into the motion Fold, with various variable arguments set by whatever you type into the various menu option boxes.
  • Koppel
    19
    132
    • December 31, 2019 at 4:20 PM
    Do I understand correctly that if I do not make a call to the external program BAS.SRC, the inline forms in my program will not work and I will not be able to create new ones.
    What are the risks if I do not include the row:
    EXT BAS (BAS_COMMAND :IN,REAL :IN )
    BAS (#INITMOV,0 )
    Tools, Bases, Speeds, Accelerations can remain unchanged from the previous program that was run before?
  • AndrewWang
    63
    • January 2, 2020 at 2:30 AM
    Quote from Koppel
    BAS (#INITMOV,0 )
    If you are experienced , it's no need to use BAS(#INITMOVE,0).For example:
    FDAT_ACT=FDEFAULT
    FDAT_ACT.TOOL_NO=1
    FDAT_ACT.TOOL_NO=1
    FDAT_ACT.IPO_FRAME=#BASE
    BAS(#FRAMES)
    PDAT_ACT=PDEFAULT
    PDAT_ACT.VEL=50
    PDAT_ACT.ACC=20
    PDAT_ACT.APO_DIST=5
    PDAT_ACT.APO_MODE=#CDIS
    BAS(#PTP_DAT)
    PTP {X 100 ,Y -100 ,Z 810 ,A 0 ,B -20 ,C 75} C_DIS
    SkyeFire
    1,061
    9,463
    • January 2, 2020 at 8:34 PM
    The EXT BAS line is a holdover from waay back in KSS 2.x, or maybe earlier, where it was necessary to use the EXT command to create a callable connection between one module and another. It hasn't been necessary for quite a few versions now.
    The BAS (#INITMOV) call is just boilerplate to set the initial motion settings. It sets all the motion parameters to their default values, so you can immediately use a PTP motion to achieve BCO, after which all PTP, LIN, and other motions will be available.
    So, the INITMOV is not necessary, but something to set the motion parameters must be performed before executing any motion commands. This can be done by calling BAS with different individual options, as Andre showed, or by directly setting each parameter individually in your own executable code. BAS is just provided to make things much easier.
  • gar_car
    5
    • May 1, 2020 at 6:06 PM
    Hi. I´m new too with KUKA robots (i have worked with ABB) and i'm just started learn krl language with WorkVisual but don't have access to a KUKA robot. Could you provide me the BAS.src file and other filesn that exist in a real controller? Thanks in advance.
  • panic mode
    1,297
    13,141
    • May 1, 2020 at 6:36 PM
    enjoy
    Files
    BaseProject.zip 1.6 MB – 366 Downloads
  • gar_car
    5
    • May 1, 2020 at 6:59 PM
    Thanks man!
  • panic mode
    1,297
    13,141
    • May 1, 2020 at 7:05 PM
    hey did you just assume my gender? :thumbs_up::grinning_face_with_smiling_eyes:
  • Timo P
    • January 7, 2022 at 9:31 AM
    • #11
    I have a question regarding calling the BAS function. Would calling the function in the middle of a running program, more specifically between motion commands cause the advance pointer to stop?
    Bellow is an example of a motion with tool switching, assuming all motion parameters have been prepared somewhere above.
    BAS(#BASE, 1)
    BAS(#TOOL, 1)
    $advance = 3
    PTP Pos1
    PTP Pos2 C_DIS
    BAS(#TOOL, 2)
    PTP Pos3 C_DIS
    Would approximation work in this case? And if it does, what would happen if the advance pointer changes the tool before the main pointer starts the first motion, would it still go to Pos1 with tool1 or would it use tool2?
  • hermann
    412
    2,629
    • January 7, 2022 at 9:35 AM
    • #12
    It will use tool 1, as wished.
    Approximation depends on changing load data or not (AFAIK).
  • Fubini
    284
    1,906
    • January 7, 2022 at 9:51 AM
    • #13
    Quote from hermann
    Also depends on absolute accuracy, Load changes are no problem without absolute accuracy.
  • Timo P
    • January 7, 2022 at 10:11 AM
    • #14
    Quote from hermann
    The tools have different transformation/TCP, but the change in Load data between them is not too big it think ~10% for inertia.
    Do you maybe know if the call of "BAS" itself would cause a advance run stop with the "IF" statement that are inside the function? I am having some problems where sometimes the approximation works and sometimes it stops at the start of the approximation and then again at the end before continuing motion. i have moved all functions and outputs to Trigger commands but still something is stopping the advance run.
  • Timo P
    • January 7, 2022 at 10:47 AM
    • #15
    Quote from hermann
    Would this also apply to frame stored in a variable?
    $Advance = 3
    ;Go to Pos1 with offset 500
    Pos1.BaseOff = $NULLFRAME
    Pos1.BaseOff.Z = 500
    LIN Pos1.BaseOff : Pos1
    ;Go to Pos1 with offset 0
    Does the 1. Lin use 500 as an offset even if the advance pointer already went over the second assignment of "Pos1.BaseOff"
  • Fubini
    284
    1,906
    • January 7, 2022 at 1:03 PM
    • #16
    Quote from Timo P
    No. An if does not trigger an advance run stop. Its the evaluation condition inside the if that triggers the stop. If for example an input or output needs avaluation. The BAS functions apart from BAS(#INITMOV) do not trigger advance run stops apart the before mentioned load change in case of absolute accuracy. Here it is irrelevant whether ist 10% or 0.001%. A change is a change.
    So ypur problem must be hidden elsewhere. Did you check with $STOPNOAPROX?
    Quote from Timo P
    Sure. why would it not be. All thesese expressions are evaluted in advance run in the same order they are written in the program.
    Quote from Timo P
    Yes it uses 500. All the expressions are evaluated in advance run. In the given sequence order by the program. The Advance run can not be behind the First Lin when evaluating
    Fubini
    SkyeFire
    1,061
    9,463
    • January 7, 2022 at 4:09 PM
    • #17
    Quote from Timo P
    Depends on the parameters. Calling BAS(#INITMOV...) will break the ARP. But if you examine the inside of any motion Inline Form, you'll see that they set Base, Tool, Approximation, and Velocity data (among others) by calling BAS with other parameters without breaking the ARP.
    Different subroutines inside the BAS module have different effects on the ARP. You can count on the ones used by the ILFs to not break the ARP.
  • jaiiyer
    16
    91
    • February 24, 2025 at 10:54 PM
    • #18
    Quote from panic mode
    I admire you panic mode
  • panic mode
    1,297
    13,141
    • February 25, 2025 at 12:38 AM
    • #19
    :smiling_face_with_smiling_eyes:
  • RoboTux
    15
    • June 19, 2025 at 3:49 PM
    • New
    • #20
    Quote from hermann
    Oh my God! The load data! I don't think this touch the approx. I read all manual, read the BAS, but here is the solution. Big thanks!
    ABB Robot -Programming - Service - Maintenance - Training
