Remote Auto/T1 Switch?
  • Duranthas
  • April 15, 2015 at 6:05 PM
  • Duranthas
    39
    Is it possible to mount a second switch remotely to switch the controller from Auto to T1 on a R-30iB controller? Long story short, there are 3 R-30iB controllers connected to M-10iA robots. The robots and teach pendants are on one side of a conveyor and the controllers on the other. We would like to have a switch for each robot mounted near the door and unfortunately we don't have the floor space near the door to place the controllers on a more accessible side.
  • rumblefish
    19
    131
    • April 15, 2015 at 7:22 PM
    It's not uncommon to remove the mode keyswitch and relocate it where you need. We get asked to do this more often than not. Dual keys is not something we've tried, if the key and tp are together there isn't much of a need to have one on the controller.
  • Fabian Munoz
    134
    Articles
    1,517
    • April 15, 2015 at 7:49 PM
    Duranthas
    In the end, that key switch is just a key switch like any other one.
    My only point I would not put a second switch, for safety reasons. I would just move/disable/remove the one on the controller and had only the one you need
    Retired but still helping
  • Duranthas
    39
    • April 16, 2015 at 2:39 AM
    Can this be done using a standard wire pull through conduit or does Fanuc require a cable of some sorts?
    And thanks for the responses. I appreciate it.
  • dha
    29
    397
    • April 16, 2015 at 7:36 AM
    This is possible with DCS and option J569 External Mode Select.
    We have done it and it is working.
  • scotty
    43
    5
    497
    • April 16, 2015 at 7:45 AM
    Duranthas,
    Maybe DO signal of your robot's state can help you.
    Image in attache
    Files
    .PNG 2.13 kB – 337 Downloads .PNG_thumb 6.39 kB – 251 Downloads
    Edited once, last by scotty (April 16, 2015 at 3:37 PM).
  • DaveP
    23
    201
    • April 17, 2015 at 4:44 PM
    We have moved several mode switches and use MTW or THHN wire run in conduit without any issues.
  • pdl
    270
    1,548
    • April 17, 2015 at 11:36 PM
    As to using two switches in parallel, this would be pointless, as both key switches would need to be in the same position. This would make having a remote switch more cumbersome to use then one by itself.
  • dha
    29
    397
    • April 18, 2015 at 6:32 AM
    In our case, the point of having two switches for two working areas was that when error occured, operator could switch to T1 before entering the cell. Breaking the light curtain would only stop the positioner and not the robot.
  • Skooter
    172
    2,057
    • May 7, 2015 at 2:33 AM
    dha - just curious, but why wouldn't you use HOLD and then the Fence input to stop the robot? What am I missing?
    I agree with Somar and DaveP. Moving the Mode Switch is very common, B-style controllers up on mezzanines is a good example.
  • dha
    29
    397
    • May 7, 2015 at 2:28 PM
    • #11
    After turning the key to T1, operator should take out the key and carry it while he is inside the cell.
  • rumblefish
    19
    131
    • May 7, 2015 at 3:30 PM
    • #12
    You could achieve the same ends by using gate keys/plugs and integrating them in to the fence circuit and or the servo off circuit. This will allow removal of the mode key from normal production and create a more reliable safety plan.
  • Malaki
    • June 13, 2016 at 6:49 PM
    • #13
    I am using a different key switch to remote Auto/T1 and need to know what the contact configuration is on this switch
  • Thejesh
    68
    • April 28, 2019 at 8:30 AM
    • #14
    How to run program manually by just making TP on and keeping robot controller in auto mode itself in R-30 ib controller
    Sent from my Redmi Note 4 using Tapatalk
  • Sergei Troizky
    71
    664
    • May 1, 2019 at 11:42 PM
    • #15
    Quote from pdl
    The 2-position T1/AUTO switch is a pair of contacts. Both are open in T1 and closed in AUTO mode.
    Any number of additional switches may be connected in series (any one will activate T1 mode when Off) or in parallel (any one will activate AUTO mode when On).
