Hi, I very need manuals for axisconfigurator software and synchronius motion external axis (linear track),
I have a KR210 robot on KL1500 linear track, KRC2 controller with KSS 5.2.9 software.
KRC2 axisconfigurator and syncmotion external axis manual
ambersat -
November 22, 2013 at 3:14 PM -
This any help?
This any help?
i think yes, thank you very much -
Any chances somebody, has the external axis manual for KSS 8.3 ?
no problem
I want to configure an external axis on my KRC1 with KSS4.1.7. Can anyone share this manual if available?
The KRC2 manual in the earlier post should be mostly valid for KRC1. The hardware is different, but the process is the same. Although the menus may be a bit different on KRC1.
Hm... I did find an old KRC1 manual.
Help solve the error!! I connected the 7 axis, now when I try to move any axis, a DSE-RDW1 communication error occurs, if I return the factory parameters, the robot moves. What to do? How to fix it?
Set the correct machine data.
Now you know not really more than before, but you should give more informations about what you have done, post faulty machine data, describe your system, hardware and software. Then may be, you will get better help.
Thank you very much! Robot KR2240, KRC2. The external axis of the drive of its own Siemens. By the link machine datahttps://disk.yandex.ru/d/Xw9Pn5DMNMBPxQ
It's not a KUKA drive module in the KRC2? Usually using non-KUKA drives doesn't work.
For the positioner, the first axis is taken from the Cook robot KR60
So, it's a KUKA servo motor. But what is the drive module? Typically, a KRC2 needs one KSD module, inside the KRC2, for each servo motor.
From KR 60 the gearbox of the first axis, the motor and the servo. where can I find the electrical wiring diagram?? it may not be connected correctly
Why not check with Cook? I mean KUKA.
Fine. What about the DRIVER MODULE?
МОДУЛЬ ВОДИТЕЛЯ от этого робота, KSD 32. Помогите со схемой подключения, возможно я не все провода правильно подключил .
Help with the problem!!!! The positioner rotates without errors, and when trying to move the main axes, a DSE-RDW error occurs
